Home > Forums > Software User Forums > SU2 > SU2 Shape Design
Shape Optimization Error, Incorrect values produces by SU2_GDC
Old   March 19, 2014, 18:59
Default Shape Optimization Error, Incorrect values produces by SU2_GDC
Dhig is on a distinguished road
I'm quite new to su2 and cfd in general and I'm having difficulty running some of my own shape optimization problems. I'm trying to run a simple 2D half airfoil through the shape optimization software. I generated the 2D geometry and mesh in gmsh and I am running su2 that was installed in serial. As a preprocessing step I'm running SU2_GDC to find the thickness values at the fraction chord lengths(1/4 , 1/3, 1/2, 2/3, 3/4), however the code produces "#1.QNAN" for every section value. The code prints out "Bad xa input to splint routine" prior to printing out the incorrect values. From looking around the web I have found that this is due to an error with a spline function but SU2_CFD will run and produce reasonably accurate results. Attached is a image of the produced reults. Any help with this issue would be greatly appreciated.
Dhig
File Type: txt SU2_GDC ERROR.txt (664 Bytes, 4 views)
Dhig is offline   Reply With Quote
Old   March 20, 2014, 05:58
Scratch that its running fine now.
CFD based robust hull shape optimization Thouelfaqar Main CFD Forum 0 October 13, 2011 14:44
Shape optimization DoHander Main CFD Forum 0 April 28, 2011 22:28
Shape Optimization francesco_capuano FLUENT 2 April 28, 2011 11:51
Shape optimization chuls Main CFD Forum 1 October 6, 2009 04:00
SQP method for adjoint based aerodynamic shape optimization cfdbooks Main CFD Forum 2 May 26, 2009 10:40
