November 6, 2014, 15:13 |
problem about partition setting
Daquan He
Rep Power: 11 |
When I tried to run the tutorial 7 with 4 cores in my computer, there is always an error interrupt the process at the very beginning, with the error information " IOError: [Errno 2] No such file or directory: '/data/hedaquanhe/tutorial7/DESIGNS/DSN_001/DECOMP/mesh_NACA0012_rot_1.su2' "
I went to the directory and found there were 2 files generated, one is "config_PRT.cfg", the other is "mesh_NACA0012_rot.su2", it is different from that filename informed by the error information with " _1" missing. When I run it on only 1 core of my computer, it can carry out the calculation though I stopped the process after a few iterations. Can anyone help me to cope with this problem? |
December 11, 2014, 04:35 |
Ying Zhuying
Rep Power: 11 |
I have the same problem when I try running optimization with cores more than 1.
Have you solved the problem? |
January 4, 2015, 03:28 |
shape optimization.py error
Zhang Rui
Rep Power: 11 |
I met the same problem. Is it that we should modify someplace in some certain script? Hope for your answers~
January 4, 2015, 03:46 |
Thomas D. Economon
We recently updated the code so that all partitioning is completed internal to SU2_CFD, SU2_DEF, etc. This means that we no longer have SU2_PRT as a separate module that writes additional mesh files with their partition number before the .su2. Can you please double-check your installation to make sure that you're using the latest and greatest version of SU2? It's SU2 v3.2.7 that has these new features: https://github.com/su2code/SU2/releases/tag/v3.2.7 You might also download the latest version of the TestCases too (just in case) https://github.com/su2code/TestCases Hope this helps, Thomas D. Economon SU2 lead developer |
Problem setting C_MU_T with DEFINE_ADJUST | Andy | FLUENT | 3 | June 22, 2018 02:53 |
Problem setting AV | Marko | CFX | 0 | March 18, 2005 08:06 |
Problem setting C_MU_T with DEFINE_ADJUST | sarah_ron | FLUENT | 1 | February 24, 2005 12:11 |
Help setting up combustor problem | Tom | FLUENT | 0 | February 5, 2005 01:20 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
