Problem with tutorial "Constrained Optimal Shape Design of a Fixed Wing" version 4.2
Following a previous thread found in https://www.cfd-online.com/Forums/su...ixed-wing.html , I experience similar issues in executing the tutorial. Apparently, in the previous thread the problem was related with geometrical constraints (for example: MAX_THICKNESS_SEC1), and limited to version 4.3.0. However, I experience the same issue when using version 4.2 and lift as a constraint. The settings on the cfg file are the tutorial default ones. Specifically: % Optimization objective function with scaling factor % ex= Objective * Scale OPT_OBJECTIVE= DRAG * 0.1 % % Optimization constraint functions with scaling factors, separated by semicolons % ex= (Objective = Value ) * Scale, use '>','<','=' OPT_CONSTRAINT= (LIFT > 0.2864) * 0.1; (MAX_THICKNESS_SEC1 > 0.0570) * 0.1; (MAX_THICKNESS_SEC2 > 0.0513) * 0.1; (MAX_THICKNESS_SEC3 > 0.0457) * 0.1; (MAX_THICKNESS_SEC4 > 0.0399) * 0.1; (MAX_THICKNESS_SEC5 > 0.0343) * 0.1 % The error I get is: Traceback (most recent call last): File "../../../../../apps/SU2/4.2.0/bin/shape_optimization.py", line 155, in <module> main() File "../../../../../apps/SU2/4.2.0/bin/shape_optimization.py", line 99, in main options.quiet ) File "../../../../../apps/SU2/4.2.0/bin/shape_optimization.py", line 138, in shape_optimization SU2.opt.SLSQP(project,x0,xb,its,accu) File "/apps/SU2/4.2.0/bin/SU2/opt/scipy_tools.py", line 133, in scipy_slsqp epsilon = eps ) File "/apps/miniconda/lib/python2.7/site-packages/scipy/optimize/slsqp.py", line 206, in fmin_slsqp constraints=cons, **opts) File "/apps/miniconda/lib/python2.7/site-packages/scipy/optimize/slsqp.py", line 311, in _minimize_slsqp mieq = sum(map(len, [atleast_1d(c['fun'](x, *c['args'])) for c in cons['ineq']])) File "/apps/SU2/4.2.0/bin/SU2/opt/scipy_tools.py", line 216, in con_cieq cons = project.con_cieq(x) File "/apps/SU2/4.2.0/bin/SU2/opt/project.py", line 233, in con_cieq return self._eval(konfig, func,dvs) File "/apps/SU2/4.2.0/bin/SU2/opt/project.py", line 182, in _eval vals = design._eval(func,*args) File "/apps/SU2/4.2.0/bin/SU2/eval/design.py", line 142, in _eval vals = eval_func(*inputs) File "/apps/SU2/4.2.0/bin/SU2/eval/design.py", line 440, in con_cieq func = su2func(this_con,config,state) File "/apps/SU2/4.2.0/bin/SU2/eval/functions.py", line 93, in function geometry( func_name, config, state ) File "/apps/SU2/4.2.0/bin/SU2/eval/functions.py", line 471, in geometry info = su2run.geometry(config) File "/apps/SU2/4.2.0/bin/SU2/run/geometry.py", line 93, in geometry SU2_GEO(konfig) File "/apps/SU2/4.2.0/bin/SU2/run/interface.py", line 211, in GEO run_command( the_Command ) File "/apps/SU2/4.2.0/bin/SU2/run/interface.py", line 295, in run_command raise exception , message SU2.EvaluationFailure: Path = /home/GRID/s204030/SU2practice/steady_oneram6/DESIGNS/DSN_001/GEOMETRY/, Command = /apps/SU2/4.2.0/bin/SU2_GEO config_GEO.cfg SU2 process returned error '1' application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0 Thanks everyone for your help! Spyros |
