Alejandro Quirós
Rep Power: 8 ![]() |
I've tried to run a multi-objective optimization following the inv_wedge_ROE_multiobj.cfg in the directory TestCases/cont_adj_euler/wedge and the guidelines here: https://github.com/su2code/SU2/pull/292.
I used the steady_naca0012 test case in the optimization_euler test case directory as baseline and then added lift as objective function. The optimization problem is not working properly. Both drag and lift are beeing maximized as you can see in the history_project.dat, but I expected drag to be minimized. Anyone with experience using this feature can help me? I'm using v5.0. Last edited by AQuiros; January 27, 2017 at 09:58. |
Display Modes | |
solver is working in windows but not in linux | jbseo | CFX | 0 | August 30, 2016 01:20 |
[OpenFOAM.com] [v3.0+] not working anymore (note: was missing entry in .bashrc) | Jambne | OpenFOAM Installation | 1 | May 29, 2016 15:37 |
DPM parallel is not working but serial is working | johnwinter | FLUENT | 1 | March 27, 2012 03:01 |
How to do Design Optimization in Fluent 13.0? | p36288 | Fluent UDF and Scheme Programming | 1 | July 20, 2011 01:37 |
Polyhedral Optimization | Mlynam | Siemens | 2 | August 6, 2010 12:26 |
