Adjoint Calculation Error
I am running a 2D aerofoil optimization using V5.0.0; the flow solution is converged but each log_adjoint.out file shows the following: Code:
log10[Maximum residual]: -inf. Code:
----------------------- Residual Evolution Summary ---------------------- the adjoint gradients are then calculated to be zero (i think as a result of the above issue) any help would be highly appreciated! if more information on the .cfg file or .su2 grid is needed let me know. Many thanks! Tom |
What are the values you are using in the reduction factors of the CFL? This issue can happen if they are 0 since you'll be using a CFL of 0.
the CFL was positive with a value of around 0.5-1.5. the reduction factors were around 1.0-0.9. I have now gotten around the problem by modifying a cfg file from the NACA0012 steady optimization Testcase for use with my own grid and conditions. However, i am now facing the problem of the design returning to its original condition after a single 'good' design iteration. This issue is being discussed in another Thread. Thanks for the assistance. Tom |
