December 19, 2017, 03:39 |
Objective Functions
Hi everyone,
I want to perform shape optimization on a bent pipe with FFD, but I need as objective function the minimization of the pressure drop. Is it possible to implement something like this in su2? If yes, how should I do that? Thank you, Martina |
January 2, 2018, 09:52 |
Ole Burghardt
Rep Power: 10 |
Hi there,
it is already implemented in the current develop-branch, at least if you refer to integral-averaged values for the pressure drop. Set MARKER_ANALYZE = ( ... ) to the boundary markers where you want to evaluate the averaged pressure and OBJECTIVE_FUNCTION = SURFACE_TOTAL_PRESSURE. You can also easily adapt the calculation of the respective variables (or adding some) - have a look at COutput::SpecialOutput_AnalyzeSurface in output_structure.cpp. Regards, Ole |
ffd, objective function, shape optimization |
How to solve the boundary layer without wall functions? | WhiteW | OpenFOAM Running, Solving & CFD | 4 | January 20, 2020 04:55 |
what are the scaling factors of Optimization objective and constraint functions ? | mechy | SU2 Shape Design | 4 | September 22, 2017 03:23 |
Shape optimization: EFFICIENCY objective clarification. | fluxCatcher | SU2 Shape Design | 0 | August 10, 2017 07:39 |
[Commercial meshers] CCM+ Mesh Conversion | Ingenieur | OpenFOAM Meshing & Mesh Conversion | 17 | February 2, 2014 09:34 |
Delta Functions within Ansys Mechanical | Stephen Waite | Structural Mechanics | 2 | July 29, 2013 08:56 |
