What's the meaning of "scaling factor" in the optimization configure file? |
Bingfei
Rep Power: 9 ![]() |
Hi all,
I'm trying the ONERA M6 optimization in SU2. When I'm reading the inv_ONERAM6_adv.cfg file. I don't understand the exact meaning of "scaling factor" in the configure file. For example: % Optimization objective function with scaling factor % ex= Objective * Scale OPT_OBJECTIVE= DRAG * 0.1 % % Optimization constraint functions with scaling factors, separated by semicolons % ex= (Objective = Value ) * Scale, use '>','<','=' OPT_CONSTRAINT= (LIFT > 0.2864) * 10.0; (MAX_THICKNESS_SEC1 > 0.0570) * 0.1; (MAX_THICKNESS_SEC2 > 0.0513) * 0.1; (MAX_THICKNESS_SEC3 > 0.0457) * 0.1; (MAX_THICKNESS_SEC4 > 0.0399) * 0.1; (MAX_THICKNESS_SEC5 > 0.0343) * 0.1 % What's the meaning of the value that DRAG, LIFT, MAX_THICKNESS multiply? And same: % FFD_CONTROL_POINT ( 7, Scale | Mark. List | FFD_BoxTag, i_Ind, j_Ind, k_Ind, x_Mov, y_Mov, z_Mov ) What's the exact meaning of the "Scale" here? And what's the difference between these "Scale"? Any hint will be welcome! Thank you! ![]() Bingfei |
Francisco Palacios
Rep Power: 14 ![]() |
The new shape tutorials explain the optimization parameter a little bit better,
https://su2code.github.io/tutorials/home/ Best, Francisco |
Display Modes | |
[OpenFOAM.org] Patches to compile OpenFOAM 2.2 on Mac OS X | gschaider | OpenFOAM Installation | 136 | October 10, 2017 18:25 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 22:53 |
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 | towanda | OpenFOAM Community Contributions | 6 | September 5, 2015 22:03 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 04:23 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 02:24 |
