Home > Forums > Software User Forums > SU2 > SU2 Shape Design
2D Optimization Constraints Not Satisfied
Old   November 2, 2017, 15:44
Default 2D Optimization Constraints Not Satisfied
tom pratt
tomp1993 is on a distinguished road
HI,
I am running a 2D supersonic aerofoil optimization using the Hicks-Henne type design variables, after finding 2D FFD unsuccessful.
The new HH parametrization is successfully updating the geometry to reduce drag, however the thickness constraint is not satisfied by each resulting design, and after 7-8 design iterations the geometry becomes unfeasible due to extreme surface deformations.
2D-opt-config.txt
Config file attached above, any help would be very greatly appreciated!
Tom.
tomp1993 is offline   Reply With Quote
Old   January 15, 2018, 11:03
Question Still not solved
tom pratt
Hi Everyone,
Bumping this thread since i've still not managed to solve this issue.
The Latest copies of the cfg and grid are no longer producing infeasible deformations, but are still not complying with the aerofoil max thickness constraint as specified in the config file.
At this point i'm really struggling to see a way of making this work? any help would be greatly appreciated. unfortunately cannot upload grid file due to size limits.
2D-opt.txt
obj-func-output.txt
history_project.txt
Thanks!
Tom
Old   February 24, 2018, 13:36
Francisco Palacios
fpalacios is on a distinguished road
Not a bad idea to take a look at the new tutorial... optimization with constraints could be tricky https://su2code.github.io/tutorials/home/
Best,
Francisco
fpalacios is offline   Reply With Quote
Multiple constraints for optimization problem diwakaranant SU2 1 August 12, 2014 18:52
Geometric Constraints and Gradients for Constrained Wing Optimization Tommy Chen SU2 5 January 29, 2014 11:00
Total force optimization or pressure force optimization? robyTKD SU2 Shape Design 1 August 19, 2013 15:54
COMSOL: optimization applied to a laminar flow tdh89 COMSOL 0 April 30, 2012 08:57
Limit in Number of Simple Constraints Luis Rojas-Solorzano CFX 6 September 18, 2002 09:30
