Which basis function does SU2 employ in FFD technique of Shape Design Module? |
April 7, 2018, 04:26 |
Bingfei
Rep Power: 10 |
Hey all,
Which basis function does SU2 employ in FFD technique of Shape Design Module? Bernstein, B-Spline or NURBS? I learned these three basis functions from literature. May be it is another one that I didn't mentioned. Bingfei |
April 15, 2018, 15:58 |
tom pratt
Rep Power: 10 |
Hi Bingfei,
please check the contents of config_template.py which would be included within your SU2 master file. look for the line "FFD_BLENDING". this provides options for you to use different types of basis functions according to your preference or design requirements. best wishes Tom |
April 19, 2018, 11:09 |
Bingfei
Rep Power: 10 |
Thanks Tom for your reminding!
I found the "FFD_BLENDING" in the config_template.cfg. And I saw there's two option of the "FFD_BLENDING": BEZIER and BSPLINE_UNIFORM. But I didn't use this function in my configuration file when doing shape optimization operation. So how can I know the basis function of FFD in SU2 by default? Bingfei |
April 24, 2018, 07:25 |
Tim Albring
Rep Power: 10 |
In the config_template.cfg file you can find all available config options along with their default values.
Tim
Developer Director @ SU2 Foundation Get involved:
April 25, 2018, 10:12 |
Bingfei
Rep Power: 10 |
Thanks Tim!
I think I understand and find the default basis function of FFD. Bingfei |
Display Modes | |
FFD shape deformation for 3D wing not changing the mesh | lwc24 | SU2 Shape Design | 5 | August 1, 2019 16:17 |
Error while running "Constrained Optimal Shape Design of a Fixed Wing" tutorial | balav94 | SU2 | 1 | September 29, 2018 13:52 |
Problem with Tutorial "Constrained Optimal Shape Design of a Fixed Wing"" | MarcF | SU2 Shape Design | 3 | December 9, 2016 05:30 |
Question about SU2 optimization | YoniHe | SU2 Shape Design | 3 | January 15, 2016 01:31 |
Info: Short Course On Thermal Design of Electronic Equipment | Arnold Free | Main CFD Forum | 0 | August 10, 1999 11:18 |
