Can SU2 shape optimization function get the minimum value of Lift? |
April 5, 2018, 00:39 |
Bingfei
Rep Power: 10 |
Hi all,
I'm trying to optimize a model with the shape optimization function of SU2. The Lift of the wing that I want to optimize is negative value. My aim is getting the minimum value of Lift (that is the maximum value in the negative direction). I tried OPT_OBJECTIVE= LIFT*-1.0 or OPT_OBJECTIVE= LIFT*1.0 But no matter what I tried, the optimization always proceed towards the direction of the maximum value of Lift (the minimum value in the negative direction) :/ So I want to know if SU2 can get the minimum value of Life for my situation? If it can, what can I do realize it? Thank you. Bingfei |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 11:04 |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 07:15 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 00:35 |
