João Lourenço
Rep Power: 8 ![]() |
Hi everyone,
I would like to know if it is possible to performed in SU2 an objective function that optimize a lift-to-drag ratio.If it is what is the name of configure option. Thanks, João Lourenço |
tom pratt
Rep Power: 9 ![]() |
João,
look at the options at the bottom of the config_template.cfg file. you can use the option OPT_OBJECTIVE to define the objective for your optimisation. you can use the same options listed for either objective or constraints, e.g: Code:
% Available flow based objective functions or constraint functions % DRAG, LIFT, SIDEFORCE, EFFICIENCY, % FORCE_X, FORCE_Y, FORCE_Z, % MOMENT_X, MOMENT_Y, MOMENT_Z, % THRUST, TORQUE, FIGURE_OF_MERIT, % EQUIVALENT_AREA, NEARFIELD_PRESSURE, % TOTAL_HEATFLUX, MAXIMUM_HEATFLUX, % INVERSE_DESIGN_PRESSURE, INVERSE_DESIGN_HEATFLUX, % SURFACE_TOTAL_PRESSURE, SURFACE_MASSFLOW % SURFACE_STATIC_PRESSURE, SURFACE_MACH best wishes Tom |
#3 | |
João Lourenço
Thanks for you help. Can you help me in one more thing? If I want to introduce a pitching moment constraint of Mz => -0.087, how I introduce that in SU2? I don't know the axis direction and moments in SU2 and this leave me crazy. Thanks for you attention, João Lourenço |
#4 | |
João Lourenço
Hi Tom, Thanks for your help. Best, Joao |
Display Modes | |
Calculation of lift and drag coefficients on airfoil | CoolHersheys | OpenFOAM Post-Processing | 5 | September 27, 2021 07:04 |
How to calculate lift, drag and lift distribution in Star CCM+? | israelcasillas94 | STAR-CCM+ | 4 | November 6, 2020 09:35 |
wrong SU2 calculation for lift and drag coefficient for NAC4421 | mechy | SU2 | 7 | January 9, 2017 06:18 |
[OpenFOAM] Display lift and Drag in paraview | SamerAli | ParaView | 1 | May 16, 2013 13:51 |
Correct lift but wrong pressure drag - possible? | zx | Main CFD Forum | 4 | July 28, 2007 00:38 |
