dave73
Rep Power: 0 ![]() |
I recently did the quickstart example here: https://su2code.github.io/docs/Quick-Start/ However, I modified the mach and the AOA. The mach is fixed at 0.3. In one simulation the AOA is 2.8 and in the other it's 3.0. Here are the CL/CD outputs for each simulation: AOA: 2.8 CL/CD: 3.7 AOA: 3.0 CL/CD: 841.20 This seems like a pretty big change for such a small AOA change. Does anyone know if this is correct? Thanks, -D p.s. I don't think it's an optimization problem in the sense that the KKT condition is met after 215 and 263 iterations, respectively. |
cl/cd versus aoa |
Display Modes | |
Help with writing a macro/UDF_file/script to change BC at regular time step intervals | Codophobia | Fluent Multiphase | 0 | April 24, 2014 11:07 |
Wrong Drag and Lift Coefficient when changing AoA | inspiron | FLUENT | 1 | November 27, 2013 14:00 |
how to change the inlet flow aoa | rushit_31 | CFX | 2 | November 14, 2013 17:40 |
How to change molecular weight of a species in pdf-mixture | Jenny_W | FLUENT | 0 | November 3, 2012 17:49 |
Simulating flow past airfoil with different AOA | Quarkz | Main CFD Forum | 2 | January 6, 2006 11:56 |
