Home > Forums > Software User Forums > SU2 > SU2 Shape Design
Problem with restart of unsteady flows using shape_optimization.py
Old   January 30, 2020, 14:13
Default Problem with restart of unsteady flows using shape_optimization.py
Eduardo de Oliveira Carvalho
Eduardo Carvalho is on a distinguished road
Hi all,
I'm trying to optimize bluff bodies in unsteady flows at SU2 v6.2.0, and I'm having problems using previous data as restart parameters.
I already tested the restart solution for steady flows optimization and it worked fine. When I implemented it with dual time-stepping, the script ignores the restart command and starts using values from freestream.
It seems like the script has one kind of "fail-safe" to ignores the "RESTART_SOL=YES" command when it doesn't find the "solution_flow.dat". So I tried using a time step solution from a previous simulation, the script doesn't neglect the restart command, but asks for numbered solutions (e.g. solution_flow_00000.dat, solution_flow_00001.dat, solution_flow_00002.dat, ...).
I tried again, this time adding the numbered solutions to the working directory, but again the script stops soon after ending the direct simulation. The log indicates that this occurs because of an index error of the "history_direct.csv".
In short, I'm not finding what are the necessary files and configurations to restart this unsteady shape optimization.
I would like to know if someone can explain how to solve this problem.
Thank you for your attention.
Eduardo Carvalho
Eduardo Carvalho is offline   Reply With Quote
restart problem, shape optimization, unsteady flow
Under Relaxation Factors(URF) in unsteady problem Maxmum FLUENT 0 August 14, 2010 18:00
SOS: About VOF-Dynamic mesh unsteady problem whpsoft FLUENT 4 May 9, 2006 19:26
Newbie Unsteady Problem Anthony FLUENT 7 March 18, 2006 12:39
unsteady state problem prasad FLUENT 0 April 4, 2002 22:44
Question concerning about unsteady problem.... ghlee Main CFD Forum 6 October 2, 1998 05:36
