2D FSI optimisation - history_direct.csv not found |
April 2, 2020, 12:23 |
#1 | |
Michalis Hadjiandreou
Rep Power: 6 |
Dear Community,
I have been trying lately to set up and run a shape optimisation for NACA0012 airfoil. After setting up the fluid and structure meshes, I created two sub-configure files (configFLOW.cfg and configFEA.cfg) and a main one (config.cfg) It was found after a few trials that it was better to combine the two meshes and enable Code:
MULTIZONE_MESH = YES My question arises after I try running: Code:
$ python3 $SU2_RUN/shape_optimization.py -g DISCRETE_ADJOINT -f config.cfg -z 2 -o SLSQP Quote:
CONV_FILENAME = history I have tried to modify the "filename" from read_plot() function to "history_direct_0.csv" and the code runs but obviously when it is required to process structural data (zone1) it cannot find any since i forced it to read only history of the fluid domain. I am a fairly new user to SU2 and most probably there is a silly mistake done from my part somewhere therefore any sort of advice would be greatly beneficial. I have also attached all config (in .txt form so just save them as .cfg when downloaded) and mesh file ( https://drive.google.com/open?id=1qY...fQvtDnHNpd3-cK ) if anyone is interested to run my case. Thank you in advance and looking forward for your reply! |
[Other] Mesh Importing Problem | cuteapathy | ANSYS Meshing & Geometry | 2 | June 24, 2017 05:29 |
[Other] Compiling hacFoam (Ubuntu 10.04)(OF2.0.0)(LAMMPS13Jul2010)) | Henrik_E | OpenFOAM Installation | 3 | September 29, 2016 16:16 |
dsmcInitialise - dsmcFoam | archymedes | OpenFOAM Pre-Processing | 94 | July 15, 2016 16:14 |
missing vtf3.h BPatch.h papi.h | linch | OpenFOAM Installation | 41 | July 24, 2012 14:45 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 03:01 |
