Lazlo |
February 26, 2020 14:01 |
Thank you for your interest,
Here is the output :
Traceback (most recent call last):
File "/home/lazlo/bin/shape_optimization.py", line 176, in <module>
main()
File "/home/lazlo/bin/shape_optimization.py", line 108, in main
options.nzones )
File "/home/lazlo/bin/shape_optimization.py", line 152, in shape_optimization
SU2.opt.SLSQP(project,x0,xb,its,accu)
File "/home/lazlo/bin/SU2/opt/scipy_tools.py", line 133, in scipy_slsqp
epsilon = eps )
File "/usr/lib64/python3.7/site-packages/scipy/optimize/slsqp.py", line 208, in fmin_slsqp
constraints=cons, **opts)
File "/usr/lib64/python3.7/site-packages/scipy/optimize/slsqp.py", line 399, in _minimize_slsqp
fx = func(x)
File "/usr/lib64/python3.7/site-packages/scipy/optimize/optimize.py", line 300, in function_wrapper
return function(*(wrapper_args + args))
File "/home/lazlo/bin/SU2/opt/scipy_tools.py", line 383, in obj_f
obj_list = project.obj_f(x)
File "/home/lazlo/bin/SU2/opt/project.py", line 233, in obj_f
return self._eval(konfig, func,dvs)
File "/home/lazlo/bin/SU2/opt/project.py", line 202, in _eval
vals = design._eval(func,*args)
File "/home/lazlo/bin/SU2/eval/design.py", line 147, in _eval
vals = eval_func(*inputs)
File "/home/lazlo/bin/SU2/eval/design.py", line 244, in obj_f
func += su2func(this_obj,config,state) * sign * scale * global_factor
File "/home/lazlo/bin/SU2/eval/functions.py", line 92, in function
aerodynamics( config, state )
File "/home/lazlo/bin/SU2/eval/functions.py", line 255, in aerodynamics
info = su2run.direct(config)
File "/home/lazlo/bin/SU2/run/direct.py", line 77, in direct
SU2_CFD(konfig)
File "/home/lazlo/bin/SU2/run/interface.py", line 112, in CFD
run_command( the_Command )
File "/home/lazlo/bin/SU2/run/interface.py", line 292, in run_command
raise exception(message)
RuntimeError: Path = /media/data/lazlo/Logiciels/git/SU2/Tutorials/Inviscid_2D_Unconstrained_NACA0012 DA/DESIGNS/DSN_002/DIRECT/,
Command = mpirun -n 8 /home/lazlo/bin/SU2_CFD config_CFD.cfg
SU2 process returned error '139'
[server01:6556 :0:6556] Caught signal 11 (Segmentation fault: address not mapped to object at address (nil))
==== backtrace ====
[server01:6557 :0:6557] Caught signal 11 (Segmentation fault: address not mapped to object at address (nil))
==== backtrace ====
[server01:6558 :0:6558] Caught signal 11 (Segmentation fault: address not mapped to object at address (nil))
==== backtrace ====
[server01:6559 :0:6559] Caught signal 11 (Segmentation fault: address not mapped to object at address (nil))
==== backtrace ====
[server01:6561 :0:6561] Caught signal 11 (Segmentation fault: address not mapped to object at address (nil))
==== backtrace ====
[server01:6563 :0:6563] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x514)
==== backtrace ====
[server01:6555 :0:6555] Caught signal 11 (Segmentation fault: address not mapped to object at address (nil))
==== backtrace ====
0 /lib64/libucs.so.0(+0x1b25f) [0x7fb6ced4025f]
1 /lib64/libucs.so.0(+0x1b42a) [0x7fb6ced4042a]
2 /home/lazlo/bin/SU2_CFD() [0xb3d2e0]
3 /home/lazlo/bin/SU2_CFD() [0xb3ecb9]
4 /home/lazlo/bin/SU2_CFD() [0x8050f4]
5 /home/lazlo/bin/SU2_CFD() [0x806447]
6 /home/lazlo/bin/SU2_CFD() [0x806bf8]
7 /home/lazlo/bin/SU2_CFD() [0x80cb1f]
8 /home/lazlo/bin/SU2_CFD() [0x45a8e0]
9 /lib64/libc.so.6(__libc_start_main+0xf3) [0x7fb6d4e8e1a3]
10 /home/lazlo/bin/SU2_CFD() [0x4687be]
0 /lib64/libucs.so.0(+0x1b25f) [0x7f79a413225f]
1 /lib64/libucs.so.0(+0x1b42a) [0x7f79a413242a]
2 /home/lazlo/bin/SU2_CFD() [0xb3d96b]
9 /lib64/libc.so.6(__libc_start_main+0xf3) [0x7f79a52801a3]
0 /lib64/libucs.so.0(+0x1b25f) [0x7f0cdc54a25f]
1 /lib64/libucs.so.0(+0x1b42a) [0x7f0cdc54a42a]
9 /lib64/libc.so.6(__libc_start_main+0xf3) [0x7f0cde6991a3]
0 /lib64/libucs.so.0(+0x1b25f) [0x7f2bb8f4125f]
1 /lib64/libucs.so.0(+0x1b42a) [0x7f2bb8f4142a]
0 /lib64/libucs.so.0(+0x1b25f) [0x7fe60d20b25f]
1 /lib64/libucs.so.0(+0x1b42a) [0x7fe60d20b42a]
9 /lib64/libc.so.6(__libc_start_main+0xf3) [0x7fe60f35a1a3]
0 /lib64/libucs.so.0(+0x1b25f) [0x7f32782c925f]
1 /lib64/libucs.so.0(+0x1b42a) [0x7f32782c942a]
9 /lib64/libc.so.6(__libc_start_main+0xf3) [0x7f327a4181a3]
0 /lib64/libucs.so.0(+0x1b25f) [0x7f6ff004825f]
1 /lib64/libucs.so.0(+0x1b42a) [0x7f6ff004842a]
2 /lib64/libc.so.6(cfree+0x20) [0x7f6ff11fb7b0]
3 /home/lazlo/bin/SU2_CFD() [0x5f5882]
4 /home/lazlo/bin/SU2_CFD() [0xb3d366]
5 /home/lazlo/bin/SU2_CFD() [0xb3ecb9]
6 /home/lazlo/bin/SU2_CFD() [0x8050f4]
7 /home/lazlo/bin/SU2_CFD() [0x806447]
8 /home/lazlo/bin/SU2_CFD() [0x806bf8]
9 /home/lazlo/bin/SU2_CFD() [0x80cb1f]
10 /home/lazlo/bin/SU2_CFD() [0x45a8e0]
11 /lib64/libc.so.6(__libc_start_main+0xf3) [0x7f6ff11961a3]
12 /home/lazlo/bin/SU2_CFD() [0x4687be]
9 /lib64/libc.so.6(__libc_start_main+0xf3) [0x7f2bbb0901a3]
Primary job terminated normally, but 1 process returned
a non-zero exit code. Per user-direction, the job has been aborted.
mpirun noticed that process rank 6 with PID 0 on node server01 exited on signal 11 (Segmentation fault).
