January 27, 2021, 00:36 |
FFD box for axisymmetrical body part
Umut Can
Rep Power: 13 |
Hello everyone,
I am planning to use SU2 adjoint optimizer for the case in which flow problem is 3D. However, geometrical shape that I want to optimize is axisymmetric part (nothing but body of revolution). Therefore I need to alter the design points just on a single line and other internal points must deform accordingly so that axisymmetrical part stays axisymmetric. How can I define such a FFD box? Thanks |
January 28, 2021, 06:10 |
Pedro Gomes
Rep Power: 13 |
Cylindrical coordinates FFD.
I know we have the option but I never used it. Look around the testcases folder you might find an example. |
February 1, 2021, 14:20 |
Umut Can
Rep Power: 13 |
February 2, 2021, 05:29 |
Pedro Gomes
Rep Power: 13 |
February 6, 2021, 10:59 |
#5 | |
Umut Can
Rep Power: 13 |
February 6, 2021, 11:58 |
Pedro Gomes
Rep Power: 13 |
It can be done, see attached, but you need to move two points together because the FFD cannot be 0 degree around the circumference (this would probably not work directly with the shape_optimization script).
February 6, 2021, 13:37 |
#7 | |
Umut Can
Rep Power: 13 |
Any idea? |
WILLING TO PAY/ FREELANCER REQUIRED / small UDF coding force loads over body / 6DOF | acasas | CFD Freelancers | 1 | January 23, 2015 07:26 |
[DesignModeler] Creating Fluid Body Inside Solid Part | VU_Engineer | ANSYS Meshing & Geometry | 1 | February 24, 2012 21:28 |
Multi body part and fluctuating residuals | tichaona | Main CFD Forum | 0 | February 7, 2012 13:09 |
[ICEM] Meshing one body part only | serezhkin | ANSYS Meshing & Geometry | 3 | June 29, 2010 15:36 |
application part of laminar newtonian fluid past bluff body | swamysrikanth | Main CFD Forum | 0 | December 15, 2009 01:53 |
