thickness constraint error in unsteady optimization |
November 18, 2022, 13:01 |
Jianjun Zhou
Rep Power: 5 |
hello. i found when i deal with the unsteady shape optimization in naca0012 cases, the code can't run correctly with a thickness constraint. The message is shown as below.
Traceback (most recent call last): File "/usr/local/bin/shape_optimization.py", line 183, in <module> main() File "/usr/local/bin/shape_optimization.py", line 92, in main shape_optimization( options.filename , File "/usr/local/bin/shape_optimization.py", line 110, in shape_optimization config = SU2.io.Config(filename) File "/usr/local/bin/SU2/io/config.py", line 123, in __init__ tavg_keyGroup = "TAVG_" + historyOutFields[key_inner]["GROUP"] KeyError: 'AIRFOIL_THICKNESS' then i found the reason is that the 'if sentence' in below. thickness constraints is not in [historyOutFields]. who can tell me the reason ? thank you in advance! if self.get("TIME_DOMAIN") == "YES": objFuncsFields = self.get("OPT_OBJECTIVE") histFields = self.get("HISTORY_OUTPUT") diff_objective = self.get("OBJECTIVE_FUNCTION") constrFuncFields = self.get("OPT_CONSTRAINT") #OPT_OBJECTIVES if bool (objFuncsFields): for key in objFuncsFields: tavg_keyGroup = "TAVG_" + historyOutFields[key]["GROUP"] if not tavg_keyGroup in histFields: histFields.append(tavg_keyGroup) dtavg_keyGroup = "D_TAVG_" + historyOutFields[key]["GROUP"] if not dtavg_keyGroup in histFields: histFields.append(dtavg_keyGroup) #OPT_CONSTRAINTS if bool (constrFuncFields): for key in constrFuncFields: eqIneqConstrFunc = constrFuncFields.get(key) for key_inner in eqIneqConstrFunc: tavg_keyGroup = "TAVG_" + historyOutFields[key_inner]["GROUP"] if not tavg_keyGroup in histFields: histFields.append(tavg_keyGroup) |
shape optimization, thickness, unsteady flow |
Display Modes | |
shape optimization for RAE2822 with constraint on area | Mengmeng | SU2 Shape Design | 3 | September 29, 2019 18:23 |
what are the scaling factors of Optimization objective and constraint functions ? | mechy | SU2 Shape Design | 4 | September 22, 2017 03:23 |
unsteady rans optimization of NACA64A010 | hejiandong | SU2 Shape Design | 9 | April 24, 2014 09:21 |
Anyone has realized optimization for unsteady flows? | hejiandong | SU2 Shape Design | 3 | November 29, 2013 01:44 |
COMSOL: optimization applied to a laminar flow | tdh89 | COMSOL | 0 | April 30, 2012 08:57 |
