jjjjjjjjjjjjf
Rep Power: 0 ![]() |
Hi everyone,
I'm currently implementing a 2D shape optimization of a hypersonic capsule at an angle of attack of 12º using SU2. The geometry of the capsule is aligned with the x-axis, and the freestream is rotated accordingly to introduce the AoA. I'm using a 2D FFD box defined with the following configuration: MESH_FORMAT = SU2 MESH_FILENAME = malla_opt_2D_pt2.su2 MESH_OUT_FILENAME = malla_opt_2D_pt2_ffd.su2 MARKER_CUSTOM = ( wallupper, walllower, inlet, outlet ) DV_KIND = FFD_SETTING DV_MARKER = ( wallupper, walllower ) DV_PARAM = ( MAIN_BOX, 24, 1, 0.0, 1.0 ) FFD_TOLERANCE = 1E-8 FFD_ITERATIONS = 500 FFD_DEFINITION = ( MAIN_BOX, -0.1, -4, 0.0, 3.6, -4, 0.0, 3.6, 4, 0.0, -0.1, 4, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0 ) FFD_DEGREE = ( 24, 1, 0 ) FFD_CONTINUITY = 2ND_DERIVATIVE % There is a symmetry plane (j=0) for all the FFD boxes FFD_SYMMETRY_PLANE = YES I defined the design variables over all control points in the i-direction (0 to 24) and j-direction (0 and 1), applied to both wallupper and walllower. The configuration looks like: DEFINITION_DV = ( 19, 1.00 | wallupper, walllower | MAIN_BOX, i, j, 0.00, 1.00 ); (repeated for all i = 0...24 and j = 0,1) Despite setting FFD_SYMMETRY_PLANE = YES, it seems like the symmetry condition is not being enforced during the optimization. Both wallupper and walllower are intended to be symmetric, but it is not working. Has anyone encountered this issue before? Is there something wrong or missing in my setup that might cause the symmetry condition to be ignored? Thanks in advance for your help! |
bigfoot
Rep Power: 21 ![]() |
The FFD symmetry plane only works for 3D geometries.
For 2D, you can take out the degrees of freedom from the DEFINITION_DV list. You can remove the movement in the y-direction to keep the wall points on the same y-coordinate. If you also want to constrain the gradients at the wall, you could try with Code:
% Surface grid continuity at the intersection with the faces of the FFD boxes. % To keep a particular level of surface continuity, SU2 automatically freezes the right % number of control point planes (NO_DERIVATIVE, 1ST_DERIVATIVE, 2ND_DERIVATIVE, USER_INPUT) FFD_CONTINUITY= 2ND_DERIVATIVE Or you can modify the movement of the FFD points yourself with a python script before calling SU2_DEF. |
ffd 2d optimization su2, shape optimization, su2, symmetry |
Display Modes | |
Question about symmetry in Autodesk Cfd 2016 | ecto | Autodesk Simulation CFD | 0 | October 20, 2015 04:16 |
small question about the functionalities of topological changes in OpenFoam | ngj | OpenFOAM Running, Solving & CFD | 2 | February 28, 2013 10:02 |
Question Re Engineering Data Source | imnull | ANSYS | 0 | March 5, 2012 13:51 |
internal field question - PitzDaily Case | atareen64 | OpenFOAM Running, Solving & CFD | 2 | January 26, 2011 15:26 |
Poisson Solver question | Suresh | Main CFD Forum | 3 | August 12, 2005 04:37 |
