June 5, 2013, 04:44 |
Residuals are NAN with unsteady plasma flows
Raffaele Pepe
Hi developers,
I'm trying to run unsteady plasma calculations. I modified the configuration file of Tutorial 1-Bump in a Channel, in order to deal with unsteady argon plasma flows. Residuals are NAN using either TIME_STEPPING or DUAL_TIME_STEPPING-1ST_ORDER. Log output is in the attached file SU2log.txt. There are some testcases for unsteady plasma computations? Thanks in advance Raffaele |
June 5, 2013, 05:30 |
Raffaele Pepe
I have fixed the problem. I have trouble with SU2 2.0. Using latest version, SU2 2.0.4, unsteady plasma computations work well. Thank you anyway Raffaele |
Parallel simulation of unsteady flows | MLJ | Main CFD Forum | 5 | June 14, 2000 01:24 |
Non-Reflecting BC for unsteady Euler flows | Rob Law | Main CFD Forum | 1 | October 4, 1999 16:46 |
k-omega model and unsteady transition | Jens Thurso | Main CFD Forum | 1 | May 4, 1999 09:50 |
Unsteady flows in branched pipes | Andrei Chernousov | Main CFD Forum | 0 | February 10, 1999 04:04 |
1D simulation of unsteady gas flows in pipelines | Andrew Chernousov | Main CFD Forum | 1 | September 4, 1998 23:42 |
