Home > Forums > Software User Forums > SU2
Moment convergence issue
Old   January 15, 2014, 01:40
Default Moment convergence issue
Rachit Prasad
Rachit is on a distinguished road
I am running a simulation to estimate the aerodynamic characteristics of a BWB delta wing configuration aircraft. The force coefficients are being approximated nicely, but the moment coefficient values are not converging at all, some other friends of mine working on the same design are facing similar issues. It would be great if someone could help.
Rachit is offline   Reply With Quote
Old   February 12, 2014, 13:58
Thomas D. Economon
economon is on a distinguished road
Hi Rachit,
Are you finding that the residuals are converging in SU2? Could you share more information or console output?
If the solver converges ~6 orders of magnitude in the density residual, for instance, I would expect that both the force and moment coefficients should be relatively well converged.
Cheers,
Tom
economon is offline   Reply With Quote
Centrifugal pump convergence issue bhatiadinesh CFX 6 April 3, 2020 06:57
Convergence issue with continuity equation Jake FLUENT 8 June 6, 2018 03:41
convergence issue with turbulence mar Siemens 5 February 2, 2015 02:42
Continuity convergence issue for a multiphase flow in a counterflow heat exchanger Andrea1984 Fluent Multiphase 2 July 24, 2013 04:55
Turbomachinery Convergence Issue CFX 11 sherifkadry CFX 0 May 29, 2009 13:07
