Home > Forums > Software User Forums > SU2
su2 domain decomposition
Old   October 25, 2013, 09:31
Default su2 domain decomposition
Tom Jentink
jentink is on a distinguished road
I'm running a larger problem now to compare surface heating with some LAURA results. The grid is approximately 3.5 million points (structured).
Upon startup, it takes SU2 over 15 minutes to prep the grid. When I restart using the same decomposition, it still goes through the same process - Is there a way to keep the domains from the decomposition and re-use them when restarting the problem?
Also, I was wondering why the restart file is formatted? It's huge for a grid of 3.5 million points and it'd be nice if it was unformatted.
jentink is offline   Reply With Quote
Old   November 5, 2013, 17:15
Thomas D. Economon
economon is on a distinguished road
Hi Tom,
Indeed, you re-use the old grid partitions, and this was the original intent, especially when running design problems with multiple SU2 modules. Use the option "-d False" when calling parallel_computation.py. As a note, you can always see the available options with the python scripts by using the option "--help" at the command line.
Cheers,
Tom
economon is offline   Reply With Quote
Domain decomposition and Ax=b?? pkr OpenFOAM Running, Solving & CFD 1 March 30, 2011 08:31
Domain Decomposition ertan Main CFD Forum 2 September 1, 2009 12:22
CFX - domain decomposition. Urgent!!!! Elena Saldaeva CFX 4 June 30, 2008 07:18
rotating domain in rotating domain, different axis Robert Stringer CFX 3 December 4, 2006 07:04
Domain decomposition rajesh Main CFD Forum 2 August 31, 1999 04:22
