With restart, "solution file doesn't match mesh" |
July 12, 2016, 15:22 |
Rep Power: 9 |
I am running an unsteady simulation. I found that my simulation time was too small, so I am trying to restart the solution and extend the simulation time. I set up the restart process in the .cfg file, but I get the following error: "The solution file [flow.dat] doesn't match with the mesh file. It could be empty lines at the end of the file." There are no empty lines at the end of the file. And I only have one .cfg and one .su2 file, so I'm not sure what to do to get the two to match. Any suggestions? Thanks. |
July 20, 2016, 14:19 |
#2 | |
Heather Kline
Rep Power: 13 |
Note that for unsteady restarts, depending on the type of unsteady simulation, you may need multiple restart files - it will give a similar error stating the file name it expects. |
restart solution |
Display Modes | |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 04:30 |
wmake compiling new solver | mksca | OpenFOAM Programming & Development | 14 | June 22, 2018 07:29 |
[OpenFOAM.org] Patches to compile OpenFOAM 2.2 on Mac OS X | gschaider | OpenFOAM Installation | 136 | October 10, 2017 18:25 |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 07:42 |
[swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 14:59 |
