February 1, 2014, 00:03 |
Unsteady simulation for NACA0012 airfoil
Anant Diwakar
Rep Power: 13 |
Hi
I am trying to run unsteady flow simulation for NACA0012 airfoil for Mach = 0.5, Re = 10000 and AoA = 0 degree The flow is unsteady for this case due to vortex shedding. But I am not able to get this result in SU2. I am not getting any periodic oscillations in lift/drag coefficients with time. I am attaching the .cfg used. Can anyone tell why is this happening ? Thanks Anant |
February 1, 2014, 07:19 |
Eduardo Molina
Rep Power: 15 |
Hi Anant.
Your configuration file is correct. I think your teste case is incorrect! How can you expect periodic vortex shedding on a symmetric airfoil with AoA=0???? Where did you see this? Can you show to us? Regards Eduardo |
February 1, 2014, 12:52 |
Anant Diwakar
Rep Power: 13 |
Hi
Please refer to this paper by M. Braza http://www.sciencedirect.com/science...45793002001007 Thanks Anant |
February 1, 2014, 21:00 |
David Manosalvas-Kjono
Rep Power: 12 |
Anant,
Your config file looks fine for what you are trying to model. A few suggestions that work very good when trying to model vortex shedding on bluff bodies are:
David |
February 18, 2014, 06:10 |
Anant Diwakar
Rep Power: 13 |
Hi
I tried using restart file to induce some disturbance, but still I am not getting the flow as mentioned in the paper attached in the Post 2 of this thread. The config file is attached (without restart option). I am using the hybrid mesh for NACA0012 given in the testcases folder ( mesh_NACA0012_lam_hybrid_v3.su2). Can anyone help ? Thanks Anant |
February 19, 2014, 23:10 |
Rep Power: 12 |
Anant,
I noticed that you are using JST, and this scheme can be a bit dissipative. Try lowering the coefficient of the 4th order artificial dissipation term, about one order of magnitude, and if this doesn't work give Roe 2nd order a try. Have you tried refining your mesh and inserting a disturbance in the flow yet? Hope this helps, David |
February 20, 2014, 02:47 |
Thomas D. Economon
Rep Power: 14 |
Hi guys,
You can achieve the type of results you see in the paper above if you make a few adjustments: 1. I think a c-mesh is better suited for this case, which gives extra refinement in the wake region. 2. Check that you have ~30 mesh points in the boundary layer for this Reynolds number (laminar flow). 3. I would second that the 2nd-order Roe method should be a good choice for this problem. Please see the attached figure of SU2 results for a shedding NACA 0012 @ M = 0.8 and Re = 10,000. I have posted the files for this case here temporarily if you want to give it a try: http://www.stanford.edu/~economon/dr...m_naca0012.tgz. There are several other small changes that I've made to the config file you'll find in that directory. All the best, Tom |
February 23, 2014, 23:47 |
Anant Diwakar
Rep Power: 13 |
Hi Thomas
I tried running the simulation for Mach = 0.8, using the config file and the mesh file given by you. The results are not matching to that given in the paper. In the paper, the time period of the primary oscillation of cl coefficient is around 0.55 seconds, where in SU2 it is much less. Moreover the secondary oscillation is not observed in SU2. I am using time step for dual time stepping as 0.0001. So while plotting cl vs t, I am multiplying no. of external iterations with this time step. Please look into it. Cl vs time plot is attached. |
February 24, 2014, 22:16 |
#9 |
Thomas D. Economon
Rep Power: 14 |
Hi Anant,
I should mention that I did not optimize/investigate any of the parameters in the config file and mesh that I provided above, but rather just wanted to give an example where shedding is observed. You may want to perform a grid refinement study to make sure that the mesh is suitable for the conditions that you are simulating (again, I would recommend a c-mesh with decent resolution in the wake). You can also check that you are using exactly the same parameters as in the paper above. In particular, you may need to investigate the effect of the limiter coefficient for the 2nd-order Roe method or that the physical time step chosen is adequate to capture the effects that you are expecting. Cheers, Tom |
Problem with airfoil shape optimization | robyTKD | SU2 Shape Design | 7 | March 7, 2022 16:18 |
Comparison the airfoil 0012 experimental result and simulation result | harrislcy | FLUENT | 30 | August 29, 2013 10:27 |
Problem with restart solution in shape_optimization.py | robyTKD | SU2 Shape Design | 21 | May 29, 2013 09:26 |
result on airfoil wortmann fx63-137 simulation | jdfortune | FLUENT | 5 | January 31, 2011 19:26 |
Simulation of a moving airfoil in Fluent | M.Sc_Student | FLUENT | 2 | October 25, 2010 03:03 |
