February 8, 2013, 04:52 |
SU2 Residuals
Roberto Pieri
Rep Power: 14 |
Hallo,
I am not able to understand how residuals are calculated. Are they the sum of all residuals in each cell or the maximum value in the computational domain? And also, are values saved in the history.csv the log10 of the ratio Res/Res_ref, where Res_ref is a reference value, or simply the log10 of the residuals? Thank you, Roberto |
February 15, 2013, 20:03 |
Francisco Palacios
Rep Power: 15 |
The residual is the L-2 norm of the residual in the entire domain, and then we compute the log10.
My recommendation is to use tecplot (it is possible to obtain an evaluation copy), the paraview output is unsupported. Cheers, Francisco |
February 17, 2013, 12:44 |
Roberto Pieri
Rep Power: 14 |
Thank you Francisco for the reply.
Cheers, Roberto. |
March 15, 2013, 07:19 |
SU2 residuals
malik
Rep Power: 13 |
I am running Inviscid ONERA M6 mesh using the SU2 code. I have run it but it stops after 193 iterations, iwant to increase the number of iterations to to 1500 so plz can you tell what i have to change in cfg file. Thanks in advance Regards, Malik |
March 15, 2013, 07:36 |
Samuele Z
Rep Power: 18 |
Hi Malik,
this is the entry to change the max number of iterations Code:
% Number of total iterations EXT_ITER= 99999999999 Please, post your config file. |
March 15, 2013, 16:56 |
SU2 residuals
malik
Rep Power: 13 |
Hi samiam,
there is no error, i need to change convergence criteria thanks |
June 17, 2013, 07:51 |
Roberto Pieri
Rep Power: 14 |
I have other questions regarding residuals. 1. Where can I find the strings of the code where residuals are computed? 2. Is it possible to save residuals in the output file? I need to know at least the infinite-norm of residuals. 3. When running SU2_CFD, it prints "Maximum residual: -3.8985e+00, located at point 49659."; I think it is the maximum Res(rho) in the domain, is it right? Cheers, Roberto |
March 31, 2016, 21:55 |
#8 | |
Oliver V
Rep Power: 10 |
I'm sorry but your answer about the residuals is not clear to me. I get you use the RMS norm on the residuals, but I'm still wondering about the second question from Roberto:
(My guess is they are absolute since you only mentioned the L-2 norm... but I need to ask). Thanks, Oliver |
April 5, 2016, 18:46 |
#9 | |
Tansu
Rep Power: 12 |
for your 3rd question, as far as i know you are right, it is res(rho). Regards, Tansu |
residual |
Welcome to the Stanford University Unstructured (SU2) forum! | economon | SU2 | 0 | January 7, 2013 02:48 |
New SU2 Forum Opened at CFD Online | pete | Site News & Announcements | 0 | January 5, 2013 17:59 |
judging convergence through residuals | MachZero | Main CFD Forum | 7 | December 25, 2012 12:18 |
Strange residuals of the Density Based Solver | Pat84 | FLUENT | 0 | October 22, 2012 15:59 |
Convergence - scaled vs unscaled residuals | HS | FLUENT | 1 | November 7, 2005 05:45 |
