Some troubles about TestCases
Dear developers and users, I have some troubles about the TestCases. May somebody please help me?
My SU2 version is 3.0.0 "eagle" . And my configure are: "CXX=icpc" without metis and cgns. Here are the troubles: I cannot run some TestCases: * cont_adj_navierstokes/naca0012 * euler/channal * euler/dlrt6 * euler/lowmach_oneram6 * fluid_structure/beam2D * fluid_structure/beam3D * linear_elasticity (segmentation fault) * mesh_deformation/oneram6 * optimization_rans/steady_oneram6 * rans/nasacrm * rotating/caradonna_tung * rotating/open_rotor * wave/cylinder I ran the cases above used serial mode. So what's the problems are there?:confused: |
I did a quick check on my machine using the most recent release, and found that at least a couple of the cases you mentioned ran. For some of the test cases which are not used in the training tutorials at http://adl-public.stanford.edu/docs/...%27s+Tutorials it is possible that some settings would need to be adjusted, however that would not explain the seg fault you mention. A few options for troubleshooting: - go through the tutorials and make sure that you are using the correct commands. - reconfigure and reinstall the code - pull the 3.0.0 release from github (rather than the most recent developer release) and reinstall - pull the most recent release (in which whatever bugs you encountered may have been fixed) and reinstall. |
Thanks
