-   SU2 (https://www.cfd-online.com/Forums/su2/)
-   -   2D FFD Optimization (https://www.cfd-online.com/Forums/su2/134998-2d-ffd-optimization.html)
RLangtry May 7, 2014 15:18
2D FFD Optimization
Has anyone managed to get tge recently announced 2D FFD optimization running yet? Is there an example problem (2d_mesh.su2, 2d_FFD.su2, .cfg) for the recently announced 2D FFD optimization capability? I've managed to get 3D FFD and 2D Hicks-Henne working correctly put after watching the latest Pointwise/SU2 workshop I'm struggling to get the 2D FFD running on an airfoil.
fpalacios May 18, 2014 21:52
Hi, Thanks for your interest in SU2
In principle, the procedure is analogous to the 3D case...
1) Add to the end of the .su2 file the following
FFD_NBOX= 1
FFD_NLEVEL= 1
FFD_TAG= 0
FFD_LEVEL= 0
FFD_DEGREE_I= 25
FFD_DEGREE_J= 1
FFD_PARENTS= 0
FFD_CHILDREN= 0
FFD_CORNER_POINTS= 4
1.1 -0.1
-0.1 -0.1
-0.1 0.1
1.1 0.1
2) Run SU2_MDC with
DV_KIND= FFD_SETTING
DV_MARKER= ( airfoil )
to generate a new .su2 (the one that you will use in the future with the complete FFD information - including parametric coordinates-)
3) add the FFD design variables to the .cfg file e.g.
DEFINITION_DV= ( 15, 1.0 | airfoil | 0, 0, 0, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 1, 0, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 2, 0, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 3, 0, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 4, 0, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 5, 0, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 6, 0, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 7, 0, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 8, 0, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 9, 0, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 10, 0, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 11, 0, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 12, 0, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 13, 0, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 14, 0, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 15, 0, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 16, 0, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 17, 0, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 18, 0, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 19, 0, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 20, 0, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 21, 0, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 22, 0, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 23, 0, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 24, 0, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 25, 0, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 0, 1, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 1, 1, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 2, 1, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 3, 1, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 4, 1, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 5, 1, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 6, 1, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 7, 1, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 8, 1, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 9, 1, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 10, 1, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 11, 1, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 12, 1, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 13, 1, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 14, 1, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 15, 1, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 16, 1, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 17, 1, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 18, 1, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 19, 1, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 20, 1, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 21, 1, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 22, 1, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 23, 1, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 24, 1, 0, 1.0 ); ( 15, 1.0 | airfoil | 0, 25, 1, 0, 1.0 )
4) run the optimization
I hope this help,
Best Regards,
Francisco
454514566@qq.com August 5, 2014 09:48
1 Attachment(s)
FFD_NBOX= 1
FFD_NLEVEL= 1
FFD_TAG= 0
FFD_LEVEL= 0
FFD_DEGREE_I= 25
FFD_DEGREE_J= 1
FFD_PARENTS= 0
FFD_CHILDREN= 0
1.1 -0.1
-0.1 -0.1
-0.1 0.1
1.1 0.1
2) Run SU2_MDC with
I hope this help,
Best Regards,
Francisco
Why I face an error:
'DV_PARAM: a design variable in the configuration file has the wrong number of parameters'
the .cfg is Attachment 32828
