How to run su2 on windows and use multicore
I am running win7 ultimate and installed su2 latest version . After each run is says on 1 core . The processor is core i7 with 4 cores . How do I make use if the other cores to speed up the process ?
Regards |
In order to use multiple cores on Windows, you will need to install the parallel version according to the install directions here: http://adl-public.stanford.edu/docs/...s+Installation. Best of luck, Tom |
