Home > Forums > Software User Forums > SU2
Parameters of "SLOPE LIMITER DEFINITION"
Like Tree1Likes
  • 1 Post By fpalacios
Old   June 26, 2014, 09:51
Default Parameters of "SLOPE LIMITER DEFINITION"
Facundo
akun646 is on a distinguished road
could someone roughly explain the meaning of the parameters in the "SLOPE LIMITER DEFINITION" and how they are used? There are five parameters in the .cfg file:
- Reference element length for computing the slope and sharp edges limiters
- Coefficient for the limiter
- Coefficient for the sharp edges limiter
- Reference coefficient (sensitivity) for detecting sharp edges
- Remove sharp edges from the sensitivity evaluation
Thank you very much in advance!!
kind regards
akun646 is offline   Reply With Quote
Old   July 19, 2014, 12:15
Francisco Palacios
fpalacios is on a distinguished road
kind regards
parameters are associated with the adjoint solver, so if you are interested in the normal direct solver... do not worry about those.
On the other hand,
are the parameters that you should define in a typical implementation of the VENKATAKRISHNAN limiter... "Convergence to Steady State Solutions of the Euler Equations on Unstructured Grids with Limiters", Journal of Computational Physics
Best Regards,
Francisco
giovanni.medici likes this.
fpalacios is offline   Reply With Quote
Old   July 19, 2014, 13:39
Facundo
Originally Posted by fpalacios View Post
On the other hand,
Best Regards,
Francisco
Hi Francisco,
thank you very much for the reply!!
kind regards,
Facundo
Pro/E to ANSYS Parameterization Guide Trues ANSYS 4 April 18, 2018 06:52
Parameters rhoSimpleFoam marcus85 OpenFOAM Pre-Processing 0 May 15, 2013 10:36
Turbulence model parameters and equations Maximus91 Main CFD Forum 1 October 24, 2012 14:20
Parameters for multigrid solver HaZe OpenFOAM Running, Solving & CFD 3 January 28, 2012 03:05
Definition of limiter function for central dirrerencing scheme sebastian_vogl OpenFOAM Running, Solving & CFD 0 January 5, 2009 12:08
