Home > Forums > Software User Forums > SU2
Hybrid RANS/LES models
Like Tree4Likes
Old   June 27, 2014, 12:24
Default Hybrid RANS/LES models
Eduardo Molina
EMolina is on a distinguished road
Developers and users,
I would like to know if someone is working (or already worked) on Hybrid RANS/LES models such DES/DDES with SU2. Is it implemented in the current SU2 3.2 version?
Regards,
Eduardo.
EMolina is offline   Reply With Quote
Old   June 27, 2014, 15:56
Jianming Liu
liujmljm is on a distinguished road
Regards,
Eduardo.
I think it is very simple to add DES in SU2. In fact, I have added this. Now I am testing the DES with SA model.
liujmljm is offline   Reply With Quote
Old   June 27, 2014, 16:21
Eduardo Molina
Hi Jianming Liu,
I would appreciate if you can share your modification, I am also interested in DES with SU2.
Regards,
Eduardo.
Old   June 27, 2014, 19:03
Jianming Liu
Hi Jianming Liu,
Regards,
Eduardo.
I just modify ten files in SU2. I will show the modification here.
1. in config_structure.hpp,in class CConfig, add two data members: double Const_DES; bool With_DES;
Const_DES is constant for DES, for SA model it should be equal to 0.65
give two declaration of member function:I use following
double GetConst_DES(void);
bool GetWith_DES(void);
2 in config_structure.inl, add two definition of inline function:
inline double CConfig::GetConst_DES(void) { return Const_DES; }
inline bool CConfig::GetWith_DES(void) { return With_DES; }
3 in dual_grid_structure.hpp, add member in class CPoint
double Turb_Len_Scale_DES; /*!< \brief DES turbulent length scale */
* \brief DES turbulent length scale. JamesLiu Oct12
* \param[in] val_distance - Value of the distance.
void SetTurb_Len_Scale_DES(double val_distance);
* \brief Get the value of the DES turbulent length scale.
* \return Value of the DES turbulent length scale.
double GetTurb_Len_Scale_DES(void);
4 in dual_grid_structure.inl, add incline function
inline void CPoint::SetTurb_Len_Scale_DES(double val_distance) { Turb_Len_Scale_DES = val_distance; }
inline double CPoint::GetTurb_Len_Scale_DES(void) { return Turb_Len_Scale_DES; }
5 in file: geometry_structure.hpp, add declaration in class CGeometry
virtual void ComputeTurb_Len_Scale_DES(CConfig *config);
in class CPhysicalGeometry add
6 in file: geometry_structure.inl, add the definition
inline void CGeometry::ComputeTurb_Len_Scale_DES(CConfig *config) { }
7 in file: config_structure.cpp, in void CConfig::SetConfig_Options(unsigned short val_iZone, unsigned short val_nZone) add
addDoubleOption("CONST_DES", Const_DES, 0.65);
8 in geometry_structure.cpp, add definition of member function:
void CPhysicalGeometry::ComputeTurb_Len_Scale_DES(CConf ig *config) {
9 in SU2_CFD.cpp add
// JamesLiu for DES turbulent length scale
if ( (config_container[iZone]->GetKind_Solver() == RANS) && config_container[iZone]->GetWith_DES() )
geometry_container[iZone][MESH_0]->ComputeTurb_Len_Scale_DES(config_container[iZone]);
10 in solver_direct_turbulent.cpp change the definition of void CTurbSASolver::Source_Residual(CGeometry *geometry, CSolver **solver_container, CNumerics *numerics, CNumerics *second_numerics,
CConfig *config, unsigned short iMesh) {
use Turb_Len_Scale_DES to replace the distance of d.
Here I just show the modification I used for SA model, I think the process for DES SST model is same. I am doing the V&V for the modification. If the developers or other users have done this,
I appreciate for people to discuss this modification.
Jianming
zkdkeen and EMolina like this.
Old   June 29, 2014, 14:13
Eduardo Molina
Hi .
Thank you very much. I will perform your modifications. Did you run any validation case?
Regards,.
Eduardo.
Old   June 30, 2014, 19:45
Eduardo Molina
Hi Jianming,
I have a couple of questions:
a) In step 8, Is missing the way you compute the DES turbluent scale?
b) In step 10, you replace the GetWall_Distance() for GetTurb_Len_Scale_DES()?
c) You implemented the DES97 version or the Delayed-DES version?
Thank you very much
Regards,
Eduardo
Old   June 30, 2014, 20:10
Jianming Liu
Hi Jianming,
Thank you very much
Regards,
Eduardo
I just use DES97, the other manner, such as Delayed-DES version, I will try to add in coming days.
the overall code for the step 8 and 10, I will paste tomorrow.
Old   July 1, 2014, 11:23
Jianming Liu
Hi Jianming,
Thank you very much
Regards,
Eduardo
double *coord, dist00, dist;
unsigned short iDim, nNeigh,iNeigh; /* JamesLiu Oct12*/
unsigned long iPoint;
unsigned long No_neigh;
double xCoord_neigh;
double cdesljm;
/*--- Loop over all interior mesh nodes and compute the distances to each
of the no-slip boundary nodes. Store the minimum distance to the wall for
each interior mesh node. ---*/
cdesljm=config->GetConst_DES();
for (iPoint = 0; iPoint < GetnPoint(); iPoint++) {
nNeigh = node[iPoint]->GetnPoint();
coord = node[iPoint]->GetCoord();
dist = 1E-20;
for (iNeigh = 0; iNeigh < nNeigh; iNeigh++){
No_neigh = node[iPoint]->GetPoint(iNeigh);
dist00=0.0;
for (iDim = 0; iDim < nDim; iDim++) {
xCoord_neigh = node[No_neigh]->GetCoord(iDim);
dist00 += (coord[iDim]-xCoord_neigh)*(coord[iDim]-xCoord_neigh);
dist00=sqrt(dist00)/1.73205080757; /* sqrt(3) for unstructured grid 1.73205080757*/
if(dist00>dist)
dist=dist00;
node[iPoint]->SetTurb_Len_Scale_DES(dist*cdesljm);
Old   July 1, 2014, 11:27
Jianming Liu
Hi Jianming,
Thank you very much
Regards,
Eduardo
in void CTurbSASolver::Source_Residual(CGeometry *geometry, CSolver **solver_container, CNumerics *numerics, CNumerics *second_numerics,
first give definition for two double variables (dist00,dist00DES), then you should change the distance to the wall like following.
/*--- Set distance to the surface ---*/
// numerics->SetDistance(geometry->node[iPoint]->GetWall_Distance(), 0.0);
// JamesLiu Oct14
dist00=geometry->node[iPoint]->GetWall_Distance();
if(config->GetWith_DES()) {
dist00DES=geometry->node[iPoint]->GetTurb_Len_Scale_DES();
if(dist00<dist00DES) dist00DES=dist00;
numerics->SetDistance(dist00DES, 0.0);
else
numerics->SetDistance(dist00, 0.0);
Old   July 1, 2014, 11:30
Jianming Liu
the modification for SA-model + DES97 is developed under SU2V3.2
Old   July 2, 2014, 11:20
Jianming Liu
when you run des, you should add the option in the configure file
Old   July 2, 2014, 22:14
Eduardo Molina
Hi
In step 7 I think it is missing:
addBoolOption("WITH_DES", With_DES, false);
I follow your steps and compiled the su2 code succesfully. Once again thank you very much,
Now, I am planning to validate this DES modification using the square cylinder test case. Following this AIAA paper:
http://www.google.com.br/url?sa=t&rc...70138588,d.cWc
I create a very similar grid and now I will run this test case. If you are interested in see the 3D grid I can send you!
Meanwhile, I am seeing how we can implement the DDES version.
Regards.
Eduardo.
Old   July 3, 2014, 03:44
Jianming Liu
Hi
Regards.
Eduardo.
Yes, you are right, I am sorry I forget: addBoolOption("WITH_DES", With_DES, false);
Could you please send your grid to me. my email is jmliuxznu@163.com
thank you very much
Old   July 8, 2014, 12:17
Eduardo Molina
I send you the email.
Did you get it?
Regards.
Old   July 8, 2014, 14:20
Jianming Liu
Did you get it?
Regards.
Sorry, I just check my email now. Thank you. I get it.
Jianming
Old   July 9, 2014, 23:07
Indiana
wanjia is on a distinguished road
Hi, I am inspired by your discussion. But I still have one question after reading it. Since DES is a LES-like method which permits the instability fluctuation in it, the second order upwind scheme seems not a good choice. Have you guys checked any other high order central schemes available for viscous terms?
wanjia is offline   Reply With Quote
Old   July 10, 2014, 22:17
Eduardo Molina
Hi wanjia
Maybe you are right. I have been working with DES on commercial softwares and they are basically originated from RANS codes as SU2. Some codes are Hybrid (center-scheme in the LES region) and upwind in URANS regions. But Spalart showed in his paper that is possible to get generous LES-content even in a pure second-order upwind code. As he also said: "It is best to avoid blanket statements."
I am testing the DES capabilities with JST and the Roe scheme. When I finished I will share here with the community.
Thank you for your interest.
Regards
Eduardo
Old   July 11, 2014, 05:04
Default Hybrid URANS/LES
  #18
Albrecht vBoetticher
vonboett is on a distinguished road
I recommedn the LeMoS OpenFOAM extensions for 2.3.x
vonboett is offline   Reply With Quote
Old   July 12, 2014, 14:34
hlk
Heather Kline
hlk is on a distinguished road
Hello
Thank you for your interest in su2.
Please feel free to submit a pull request on github for any new capabilities you have developed.
hlk is offline   Reply With Quote
Old   July 12, 2014, 17:09
Jianming Liu
Originally Posted by hlk View Post
Hello
Thank you very much. I will learn how to use github.
Eddy Viscosity Models and Reynolds Stress Models JuPa CFX 1 August 20, 2013 18:56
Error quantification for Hybrid LES models M_Tidswell CFX 0 April 8, 2013 08:17
Two-fluid models vs mixture models for bubbly flows Hansong Tang Main CFD Forum 6 December 8, 2009 03:21
hybrid RANS/LES in CFX? Hao CFX 4 February 25, 2009 03:38
Hybrid mesh generation Jake Main CFD Forum 2 April 21, 2007 14:27
