akun646 |
July 18, 2014 16:16 |
Parallel computation problems with SU2 3.2
Dear users and developers,
I am facing some problems when trying to use parallel_computation.py. This is the error mesage that appears:
Traceback (most recent call last):
File "/usr/local/bin/parallel_computation.py", line 26, in <module>
import SU2
File "/usr/local/bin/SU2/__init__.py", line 3, in <module>
from . import run
File "/usr/local/bin/SU2/run/__init__.py", line 3, in <module>
from interface import \
File "/usr/local/bin/SU2/run/interface.py", line 28, in <module>
from ..io import Config
File "/usr/local/bin/SU2/io/__init__.py", line 3, in <module>
from tools import *
File "/usr/local/bin/SU2/io/tools.py", line 30, in <module>
from SU2.util import ordered_bunch
File "/usr/local/bin/SU2/util/__init__.py", line 5, in <module>
from lhc_unif import lhc_unif
File "/usr/local/bin/SU2/util/lhc_unif.py", line 1, in <module>
import numpy as np
ImportError: No module named numpy
I have installed open mpi 1.8.1 and when I configured SU2, I tried both "--with-MPI=/usr/bin/mpicxx" and "--with-MPI=/usr/bin/mpic++". But it still didn't work, could anyone give me some help with that? Thank you very much!!!!
