Time varying boundary conditions
I need to apply time varying boundary conditions to SU2 but i don't know how to do it. i looked at github and forum but there is no any topic related with it in SU2. there are many topics with other solvers but i am not sure that they are works for SU2. Is it possible to apply those kind of BC's to SU2? In other words, i have a .dat file that includes boundary conditions in node based. I mean they are not just inlet, outlet or farfield. I need to apply them to whole domain and every nodes. They are changing every time step. Is there any way to read that data to SU2. Do i need to change the .cpp code or do i need to change .cfg file or both ?? Any help is much appreciated. Thanks in advance Tansu |
In this particular case, I think it is better to change the source code. In previous version sod SU2 a method to dynamically change the Mach and angle of attack at the far-field was implemented, but you are looking for something more generic. Maybe you should take a look at the following subroutines in solver_direct_mean.cfg void CEulerSolver::SetInitialCondition(CGeometry **geometry, CSolver ***solver_container, CConfig *config, unsigned long ExtIter): and the far-field boundary conditions void CEulerSolver::BC_Far_Field(CGeometry *geometry, CSolver **solver_container, CNumerics *conv_numerics, CNumerics *visc_numerics, CConfig *config, unsigned short val_marker) { Cheers, Francisco |
Thank you Francisco. I will try to do that.
I will let you know if i could do this or not for the other users who trouble with same issue. Regards, Tansu |
Time varying pressure or velocity boundary condition in SU2
Dear All
How can we implement time varying pressure or velocity at the inlet of the domain? Something like : P(t) = P0*Sin(A*t) where t is the actual simulation time. Kindly help. Thanks |
