Convergence issue with Euler_Explicit time stepping.!!! |
December 15, 2014, 06:42 |
Vino
Rep Power: 13 |
I just tried inviscid flow over cylinder(Incompressible) with EULER_EXPLICIT time stepping and 2ND_ORDER_LIMITER. It is not converging and leading to unphysical results. But with EULER_IMPLICIT the results are fine. I would like to know whether its a bug in the solver itself. Please follow the following links for the config and grid files which I used. Config_file Grid_file |
January 1, 2015, 19:24 |
Francisco Palacios
Rep Power: 15 |
Have you tried to reduce the CFL number with the explicit formulation?
Best Regards, Francisco Palacios SU2 lead developer |
January 27, 2015, 14:27 |
Vino
Rep Power: 13 |
Thanks for you reply.
Yes.! I have tried Explicit Euler-stepping and RK-stepping with CFL number as low as 0.5. Still the problem exists. |
problem with Min/max rho | tH3f0rC3 | OpenFOAM | 8 | July 31, 2019 09:48 |
[solidMechanics] solidMechanics gear contact in rotation | nlc | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 3 | January 11, 2015 06:41 |
Sudden jump in Courant number | NJG | OpenFOAM Running, Solving & CFD | 7 | May 15, 2014 13:52 |
AMI interDyMFoam for mixer nu problem | danny123 | OpenFOAM Programming & Development | 8 | September 6, 2013 02:34 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 03:34 |
