September 8, 2014, 00:56 |
S duct NPARC validation case study
vetriselvan
Rep Power: 16 |
Dear all,
I am trying to validate SU2 v 3.0 with NPARC S duct validation case. The results seems to be incorrect. I have attached the results, configuration file and the out file. Please let me know if something has to be changed. Your help will be highly appreciated. Thanks in advance.Regards, Vetri |
September 9, 2014, 01:03 |
#2 | |
Francisco Palacios
Rep Power: 15 |
The solution has not converged... could you please try with roe + limiter, CFL =~5 and the latest version of SU2 v3.2.1 Please keep in mind that the initial condition is computed using the Mach and the Reynolds number (Freestream values) and it should be related with the inflow outflow conditions otherwise the simulation will not work. Best, Francisco |
September 12, 2014, 00:37 |
Thanks it worked :)
#3 | |
vetriselvan
Rep Power: 16 |
I used SU2 v 3.2.1 and increased the CFL number without any other changes. The solution has converged. Thank you very much.Regards, Vetri |
Duct case setup - Fan simulation | nkjsimulating | Main CFD Forum | 0 | October 10, 2013 04:15 |
solving a case on flow through duct | hariya03 | OpenFOAM Running, Solving & CFD | 0 | August 10, 2013 16:30 |
Validation case for fluid/solid interaction | Raj | Main CFD Forum | 0 | July 11, 2003 15:39 |
To verify case study | ruengsak panyasen | Main CFD Forum | 1 | July 15, 2001 15:44 |
Heat Transfer Validation test case | Chris Whitney | Main CFD Forum | 1 | July 21, 1999 14:36 |
