Multigrid Stability Issues
What is the best way to diagnose multigrid stability issues? We would like to develop a public model that demonstrates the issues, can be used to diagnose the issues, and facilitates making a more robust multigrid solver. We're running version 3.2.3, but have been tracking SU2 since version 3.2.0.
We've been evaluating SU2 to support analysis of a business jet in transonic flow. We'd like to use multigrid to improve and accelerate the solution convergence. In our evaluation, we've run into stability issues with multigrid and are not sure at this point how to diagnose the issues. We're using the following models to evaluate SU2.
We've encountered the following issues. Sensitivity to Mesh For example, multigrid parameters that work for the proprietary wing-only semi-span model do not translate to the Onera M6 and vice versa. Multi-grid parameters that work for the wing-only semi-span model do not translate to the wing-fuselage-nacelle model that has an identical wing mesh. The sensitivity to mesh is strong enough that multigrid parameters that work on the wing-only mesh fail to work with a volume mesh that is generated from an identical surface mesh with refined values for Y+ and BL growth rate. Sensitivity to Number of Partitions We've observed that changing the number of mesh partitions effects the convergence. A model that converges for a given number of cores will diverge simply by changing the number of cores. A colleague has repeatedly demonstrated this with the RANS flat plate model. We are evaluating SU2 on the following platforms.
HPC Performance Issue On the HPC Cluster, we don't see an improvement in performance when the analysis is distributed to more than 1 node. Each node has 32 CPUs and 64G. We'd like to diagnose whether this is a limitation of the interconnect, a bottleneck in the communication code, or some combination. Thanks, Tom H. |
This question was address on This week in SU2 (11-4-2014).
