Home > Forums > Software User Forums > SU2
Time Spectral Method in SU2
Old   November 17, 2014, 18:31
Default Time Spectral Method in SU2
Rachit Prasad
Rachit is on a distinguished road
I am interested in using the Time Spectral method in CFD. I used the configuration file to be used for using the Time Spectral method in SU2, on the github repository. However, on using the config file directly, I got a Segmentation Fault.
Am I supposed to do something else before running the code? Please do let me know.
Thanks in advance,
Rachit
Rachit is offline   Reply With Quote
Old   June 9, 2015, 22:54
Mi Baigang
xiaomi is on a distinguished road
hello, i also used time spectral method in SU2, but i got a error message called no-physical point, i want to know the theory of this method used in SU2, i wonder if you get any paper of this method in SU2, please let me know.
thanks
xiaomi
xiaomi is offline   Reply With Quote
Old   July 14, 2015, 16:24
Default Time spectral implementation in SU2
Sravya Nimmagadda
sravya is on a distinguished road
Rachit,
I ran the time spectral test case in the github repository and I don't find any trouble. Running the time spectral case is similar to other cases and there is nothing else you need to do in particular.
Xiaomi,
Are you running the test case in the github repository too?
The time spectral implementation on SU2 is based on the paper by Arathi Gopinath and Jameson, here is the citation for the paper
Gopinath, Arathi, and Antony Jameson. "Time spectral method for periodic unsteady computations over two-and three-dimensional bodies." AIAA paper 1220 (2005): 10-13.
sravya is offline   Reply With Quote
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 02:36
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 00:01
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
number of iterations per time step chouki FLUENT 1 August 13, 2013 00:11
same geometry,structured and unstructured mesh,different behaviour. sharonyue OpenFOAM Running, Solving & CFD 13 January 2, 2013 22:40
