Calculating reference variables
Can someone explain how reference velocity and viscosity are defined? Why free-stream values are not being used?
Here's copy of output from SU2. -------------------------------------------------------------------------------------------------------------------------- -- Input conditions: Specific gas constant: 287.058 N.m/kg.K. Free-stream pressure: 111502 Pa. Free-stream temperature: 303 K. Free-stream density: 1.28195 kg/m^3. Free-stream velocity: (13.8, 0, 0) m/s. Magnitude: 13.8 m/s. Free-stream total energy per unit mass: 217542 m^2/s^2. Free-stream viscosity: 1.86008e-05 N.s/m^2. -- Reference values: Reference specific gas constant: 287.058 N.m/kg.K. Reference pressure: 101325 Pa. Reference temperature: 303 K. Reference density: 1.16494 kg/m^3. Reference velocity: 294.921 m/s. Reference energy per unit mass: 86978.6 m^2/s^2. Reference viscosity: 343.566 N.s/m^2. -- Resulting non-dimensional state: Mach number (non-dim): 0.0395466 Reynolds number (non-dim): 35000. Re length: 0.0368 m. Specific gas constant (non-dim): 1 Free-stream temperature (non-dim): 1 Free-stream pressure (non-dim): 1.10044 Free-stream density (non-dim): 1.10044 Free-stream velocity (non-dim): (0.0467921, 0, 0). Magnitude: 0.0467921 Free-stream total energy per unit mass (non-dim): 2.50109 Free-stream viscosity (non-dim): 5.41403e-08 ----------------- EDIT: Figured out from source code. vel=f(p,rho), visc=f(rho,vel,ref_len) |
You can find some useful information in
http://su2/documents/SU2_AIAA_ASM2013.pdf Best Regards, Francisco Palacios SU2 lead developer |
