Visualize Deformation for Paraview
In the latest build of SU2 (v3.2.8) SU2_DEF gives the file surface_grid.dat as the visualization of the deformation. This file is however not readable with Paraview (4.1.0). In earlier releases, the file Surface_Grid.stl was always perfectly readable. Is this a permanent change to the surface_grid file? |
short term, reverting to version 3.2.5 will let you write the paraview files. Long term, I will add this to the github tracker. |
Hi hlk,
thank you for your reply. I was using SU2v3.2.3 when it was still working. I found that I can download previous versions of SU2 at https://github.com/su2code/SU2/releases. Are the previous versions of the test cases also saved somewhere on github? |
The tagged releases of the code and any specific commit of a repository can be checked out by git checkout <string of letters/numbers associated with that commit> from a directory where another version of that repository has been checked out. |
Thanks, I got it!
On the GitHub website I browsed in the commits to find the right release and then clicked on "Browse the repository at this point in the history". |
