Automatic mesh for airfoil coordinates?
I'm attempting to use SU2 to do a free-form airfoil shape optimization for a wind turbine blade using Kulfan parameters. The problem that I am having is that I need a method to automatically generate the .su2 mesh file based on the airfoil coordinates that I obtain from the input of my Kulfan parameters. I know this is possible because this is what appears to be done in the educational version (SU2_EDU). I am currently using a third-party software called Construct2D to automatically generate the meshes in .p3d and then convert to .su2. The problem is that when I compute the adjoint gradients with this mesh it always gives me a gradient of 0 for all the design variables. Basically, is there a code that I could use to automatically generate the .su2 mesh with the input of an airfoil coordinate file? Thank you very much for your time.
