Changing the gas model in Tne the results in error
Hi guys when the TNE tutorial with AIR-5 the simulation runs fine. But when the gas model is changed from AIR-5 to AIR-7 the following error shows up.
error: Initialize Jacobian structure. MG level: 0. terminate called after throwing an instance of 'std::bad_alloc' what(): St9bad_alloc I would be grateful for any help you could provide. Thanks. |
I believe this may be related to a known issue. https://github.com/su2code/SU2/issues/175 I have added a link to this post such that anyone who decides to try and solve it will know about this behavior as well. |
But i can not intervene Developers code to tell us more about this problem?
I found the cause that brings the program to have that bug
