SU2 installation succesful but failure when running
Hi everyone,
I've installed SU2--master in server, there is no problem in the installation. When I run Quick Start cases I got this errors : A requested component was not found, or was unable to be opened. This means that this component is either not installed or is unable to be used on your system (e.g., sometimes this means that shared libraries that the component requires are unable to be found/loaded). Note that Open MPI stopped checking at the first component that it did not find. Host: server Framework: crs Component: none -------------------------------------------------------------------------- [server:24496] *** Process received signal *** [server:24496] Signal: Segmentation fault (11) [server:24496] Signal code: Address not mapped (1) [server:24496] Failing at address: 0x28 [server:24496] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0xf0a0) [0x7fcd04d710a0] [server:24496] [ 1] /usr/lib/libopen-pal.so.0(mca_base_select+0x106) [0x7fcd05d5f356] [server:24496] [ 2] /usr/lib/libopen-pal.so.0(opal_crs_base_select+0x7e) [0x7fcd05d7159e] [server:24496] [ 3] /usr/lib/libopen-pal.so.0(opal_cr_init+0x303) [0x7fcd05d50293] [server:24496] [ 4] /usr/lib/libopen-pal.so.0(opal_init+0x17b) [0x7fcd05d4fc0b] [server:24496] [ 5] /usr/lib/libopen-rte.so.0(orte_init+0x4f) [0x7fcd05fa1b3f] [server:24496] [ 6] /usr/lib/libmpi.so.0(+0x38374) [0x7fcd06219374] [server:24496] [ 7] /usr/lib/libmpi.so.0(MPI_Init+0x16b) [0x7fcd0623a01b] [server:24496] [ 8] SU2_CFD(main+0x58) [0x4b7768] [server:24496] [ 9] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xfd) [0x7fcd049f5ead] [server:24496] [10] SU2_CFD() [0x4b985d] [server:24496] *** End of error message *** Segmentation fault Regards, Ridwan |
Hi rfadlika,
can you give me some information ? - operating system - SU2 version - configure options - command that you used to run the case - the complete output of SU2_CFD Thanks ! |
OS: Linux Mint 17.1 SU2 version (I do not know the version, but it is not educational version and I get from github SU2-master) Configure options is according to the tutorial Quick Start Command : SU2_CFD filename.cfg There is no output yet The Installation type is 'Parallel and CGNS' Thanks |
Hey Ridwan,
I would suggest you to reinstall Su2 but before that make sure you use make clean for cleaning previous file and this time before installing it make a note that you have all the prerequisite like g++(updated lib) and if you are trying for parallel make sure you have installed MPICH correctly as sometime it may give an error!! Best Ozil!! |
