November 6, 2015, 11:35 |
pressure coefficient and y+
Rep Power: 10 |
I am doing an internal flow simulation and I'd like to introduce a turbulence model. I tried to use KIND_TURB_MODEL= SA but in my results the y+ is zero everywhere. Moreover, the pressure coefficient is "-nan". Can you please link me a good reference where to understand how to set turbulence models in SU2? |
February 23, 2016, 12:07 |
#2 | |
Heather Kline
Rep Power: 13 |
- Check the console output for the projected area - if the code has found a 0 projected area, manually input this value to the config file. - Check that you are using the RANS model |
April 20, 2016, 15:33 |
Rep Power: 13 |
Have you put your surfaces u want to calculate y++ in MARKERS_PLOTTING and MARKER_MONITORING?
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 00:58 |
simpleFoam - pressure (coefficient) of head shape | GJM1991 | OpenFOAM Running, Solving & CFD | 4 | May 12, 2015 17:15 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
lid-driven cavity in matlab using BiCGStab | Don456 | Main CFD Forum | 1 | January 19, 2012 15:00 |
Automotive test case | vinz | OpenFOAM Running, Solving & CFD | 98 | October 27, 2008 08:43 |
