Volume integration of solution variable
Hi!
I need to compute a volume integral over the computational domain (for now a 2D airfoil). Specifically, I need to find {\int \int - x \nabla\cdot V dx dy}. Now I could not find any built-in capability to do so, so I have to implement it myself. Could you please give some advice on best way of doing that? My guess is that I can reuse some parts of the current code where the residuals are being computed. Thanks! |
Hi!
In this case my recommendation is to implement the formula at the level of the solver class. For example, dealing with Euler equations, you can use void CEulerSolver::Postprocessing(CGeometry *geometry, CSolver **solver_container, CConfig *config, unsigned short iMesh) { } in solver_direct_mean.cpp that it is empty. To find the name of the variables, it is useful to take a look at other well known subroutines like void CEulerSolver::Upwind_Residual(CGeometry *geometry, CSolver **solver_container, CNumerics *numerics, CConfig *config, unsigned short iMesh). In your particular case you will need something like void CEulerSolver::Postprocessing(CGeometry *geometry, CSolver **solver_container, CConfig *config, unsigned short iMesh) { unsigned long iPoint; su2double Area, dvx_dx, dvx_dy, dvy_dx, dvy_dy, x; for (iPoint = 0; iPoint < nPoint; iPoint ++) { Area = geometry->node[iPoint]->GetVolume(); x = geometry->node[iPoint]->GetCoord(0); dvx_dx = node[iPoint]->GetGradient_Primitive()[1][0]; dvx_dy = node[iPoint]->GetGradient_Primitive()[1][1]; dvy_dx = node[iPoint]->GetGradient_Primitive()[2][0]; dvy_dy = node[iPoint]->GetGradient_Primitive()[2][1]; // The formula should be computed here // a simple cout will output the result } } Thanks for using SU2, Best, Francisco |
Hi Francisco,
Thanks for your answer. However, if I use this, it computes it every MG iteration, so I moved it to output_structure.cpp. Regardless of that, the gradients always return zero. Where are the velocity gradients actually computed/which function should I call for them? I wrote the function Code:
void COutput::CompDoubletCirc(CGeometry ***geometry, Code:
for (iPoint = 0; iPoint < geometry[val_iZone][FinestMesh]->GetnPoint(); iPoint ++) { Code:
output->CompDoubletCirc(geometry_container, solver_container, |
I see...
Please notice that the gradients are computed in void CEulerSolver::Preprocessing(CGeometry *geometry, CSolver **solver_container, CConfig *config, unsigned short iMesh, unsigned short iRKStep, unsigned short RunTime_EqSystem, bool Output) { using SetPrimitive_Gradient_GG(geometry, config); or SetPrimitive_Gradient_LS(geometry, config); If you look at the code, SU2 doesn't compute gradients for centered schemes like JST. Are you running JST? If you want to be sure that you have computed the gradients maybe you can call the subroutine solver_container[val_iZone][FinestMesh][FLOW_SOL]->SetPrimitive_Gradient_GG(geometry, config); just before running your code. Best, Francisco |
Awesome, that was exactly the problem, I was using JST and the gradients weren't being computed.
Thanks! |
