Testcases for high enthalpy flows
Does SU2 has the capability to solve high enthalpy flows with thermal and chemical equilibrium/ non-equilibrium. If yes, then can you share some test-cases for it. In particular, I need to run these testcases http://citeseerx.ist.psu.edu/viewdoc...0.1.1.214.9065 Thanks Anant |
We worked on this for few years, and there was a TNE2 implementation in the GitHub branch feature_AdjTNE2. Unfortunately it is not currently supported anymore.
But you can maybe find a regression test case in some of the old versions of the code. Anyway, if you are thinking on developing a TNE2 solver... su2 is a great stating point. Cheers, Francisco |
