Home > Forums > Software User Forums > SU2
Status of the implementation of the Transition Model Gamma-Re_th
Old   April 14, 2014, 16:35
Default Status of the implementation of the Transition Model Gamma-Re_th
Giorgio
imbamba is on a distinguished road
Dear SU2 developers,
I am interested in the transition model Gamma-Reynolds_theta coupled with SA. If I look at the relative source files (SU2_CFD/src/solver_direct_transition.cpp, SU2_CFD/src/numerics_direct_turbulent.cpp, SU2_CFD/src/numerics_direct_transition.cpp ), I see a lot of comments and print statements which indicate that this particular model is still under development. Furthermore, in the last AIAA paper about SU2, this model is not mentioned anymore.
In this respect, I would like to know if you plan to continue its implementation.
Thank you very much!
best,
g.
imbamba is offline   Reply With Quote
Old   April 18, 2014, 09:11
Francisco Palacios
fpalacios is on a distinguished road
best,
g.
Thanks a lot for you interest in SU2,
The complete implementation is in place in the branch feature_transition. Currently we are in a V&V stage. The implementation has taken some time because we started with the modification for the SA model, and then we switch to the original SST based implementation.
Hopefully it will be ready in a couple of weeks,
Cheers,
Francisco
fpalacios is offline   Reply With Quote
Old   April 18, 2014, 09:19
Giorgio
Dear Francisco,
just to be sure...you are going to implement it only for the SST model, right?
Thank you very much again.
Best,
Giorgio
Old   April 18, 2014, 09:27
Francisco Palacios
Dear Francisco,
Best,
Giorgio
Yep!
Best,
Francisco
Old   July 24, 2015, 00:04
nepomaof is on a distinguished road
Hi Francisco,
Just wanted to check if you have any updates on this front - LM model implementation into SST model. Coz, when I tried adding the KIND_TRANS_MODEL = LM into either of the SA or SST cfg files for the flatplate tutorial case, a message "No LM restart yet!!" came up and I wasn't sure if I was doing anything wrong or if the implementation is still pending.
Would be great to know the current status in v4.0.0. Thanks!
Sree.
nepomaof is offline   Reply With Quote
Old   September 15, 2015, 17:41
Thomas D. Economon
economon is on a distinguished road
We are still working on the LM model for the SST. At the moment, it still has verification/testing status, but hopefully, we will be able to put it out in a future release. It is not available in v4.0.1.
Hope this helps,
Tom
economon is offline   Reply With Quote
Old   April 29, 2016, 13:56
Question Transition modelling in SU2
Kisorthman Vimalakanthan
k.vimalakanthan is on a distinguished road
Originally Posted by economon View Post
Hope this helps,
Tom
Hi economon,
I'm using the V4.1.1 'Cardinal' version of SU2, and I was wondering if the SST or SA transition model is available to use with this version?
If not could you please give some update or any advice on transition modelling on SU2..
Thanks in advance
Kind regards,
Kishore
k.vimalakanthan is offline   Reply With Quote
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
turn off wall functions in Transition SST model? johnp FLUENT 11 May 26, 2020 13:57
Why RNGkepsilon model gives floating error shipman OpenFOAM Running, Solving & CFD 3 September 7, 2013 08:00
Trans. SST Intermittency Factor and Viscosity Ratio eishinsnsayshin FLUENT 3 May 23, 2012 03:02
Missing Information in SST Transition Model Formulation Josh CFX 2 September 14, 2010 11:49
