Home > Forums > SU2
Getting Started in SU2
Old   May 5, 2016, 05:54
Default Getting Started in SU2
Jonas
JOMU is on a distinguished road
I just installed SU2 on Windows, but now I am stuck at the very beginning and probably very basic for many people here. I try to follow the guides, but it seems I am not geek enough to understand them...
  • So, after installing my files in C:\Program Files (x86)\SU2, where do I need to add quotes exactly? Do I need to add the quotes at the very beginning and very end as well?
NOTE: if the directory name contains white space, the executables may not work without appending ".exe", and the python scripts may not work. Additionally, when setting the enviornment variables and paths, quotes must be added, for example: "C:\Program Files"Stanford ADL"\SU2"
  • I saved the quick start files under D:\SU2\QuickStart. How do I execute them now? Why would SU2 find my files if I just type "SU2_CFD inv_NACA0012.cfg" into cmd.exe?
Run the executable by entering "SU2_CFD inv_NACA0012.cfg" at the command line. If you have not set the $SU2_RUN environment variable you will need to run "../bin/SU2_CFD inv_NACA0012.cfg" a the command line.
Sorry for those very beginner questions, but for me, these guides are very hard to understand...
JOMU is offline   Reply With Quote
Old   May 11, 2016, 00:59
Tom
mlooti is on a distinguished road
HI
I advise you to not waste your time on windows. this open source codes working great on Linux systems.
you can install virtual box and put an Ubuntu in that
mlooti is offline   Reply With Quote
Old   May 13, 2016, 01:35
hlk
Heather Kline
hlk is on a distinguished road
If you are set on windows, you may find this reference helpful for learning to navigate the command line:
http://lifehacker.com/5633909/who-ne...lmost-anything
For the first part, I recommend installing to a location with no spaces in the directory path to avoid potential issues. If you are sticking with the directory as-is, as far as I know, you do not need to add quotes at the beginning and end, but you may end up needing to test out either.
For the second part, you must navigate to the folder holding your config and mesh files from within the command line, and then execute the 'SU2_CFD <your config file name>' comand.
hlk is offline   Reply With Quote
Old   May 19, 2016, 23:14
JAE HWAN CHOI
chamsolli is on a distinguished road
We're about to post tutorial about running SU2 on Windows. Please keep an eye on our wiki
Best,
Jae hwan Choi
chamsolli is offline   Reply With Quote
Thread Tools
Trackbacks are On
Tool to download: SU2 post-processing Combas SU2 2 June 5, 2014 14:55
Pointwise-SU2 joint webinar (April 29th) and SU2 v3.1.0 new release fpalacios SU2 News & Announcements 1 April 30, 2014 02:40
Official release of SU2 V3.0 and SU2 Educational V1.0 fpalacios SU2 News & Announcements 2 January 22, 2014 06:28
Welcome to the Stanford University Unstructured (SU2) forum! economon SU2 0 January 7, 2013 03:48
New SU2 Forum Opened at CFD Online pete Site News & Announcements 0 January 5, 2013 18:59
