With restart, "solution file doesn't match mesh"
I am running an unsteady simulation. I found that my simulation time was too small, so I am trying to restart the solution and extend the simulation time. I set up the restart process in the .cfg file, but I get the following error: "The solution file [flow.dat] doesn't match with the mesh file. It could be empty lines at the end of the file." There are no empty lines at the end of the file. And I only have one .cfg and one .su2 file, so I'm not sure what to do to get the two to match. Any suggestions? Thanks. |
Note that for unsteady restarts, depending on the type of unsteady simulation, you may need multiple restart files - it will give a similar error stating the file name it expects. |
