Home > Forums > Software User Forums > SU2
SU2_CFD.exe has stopped working windows 7 naca0012
Old   October 15, 2013, 04:12
Default SU2_CFD.exe has stopped working windows 7 naca0012
Amir
amir00251 is on a distinguished road
I am new to SU2 and after installation, I tried to run the test file naca0012. I have copied the cfg and su2 files to a directory and run SU2.CFD.exe with cfg file, but I get "SU2_CFD.exe has stopped working" when solver starts.
Any idea what maybe wrong in Windows or in cfg file.
http://www.mediafire.com/view/kk085o...z/Untitled.jpg
Many thanks,
amir00251 is offline   Reply With Quote
Old   November 10, 2013, 00:35
wangjian
jwang1_09 is on a distinguished road
Originally Posted by amir00251 View Post
Many thanks,
The link you supplied can not be opend.Could you describe the problem more detailed?
jwang1_09 is offline   Reply With Quote
Old   August 11, 2016, 10:31
Default same problem in 2D inviscid
Deepak Prem
dpkprm is on a distinguished road
Hey, I'm trying to simulate a inviscid supersonic case of my model. Everytime I try to run the solver, I get a similar message that the SU2_CFD has stopped working and windows is trying to find the solution to the problem and the program closes. Would like to know what could be a possible cause. I have attached a screenshot of the message.
dpkprm is offline   Reply With Quote
Old   August 12, 2016, 23:08
wangjian
Attachment 49820
There are many reasons for this problem. Whether did you modify the code?
Old   August 16, 2016, 05:51
Deepak Prem
No. I didn't.
However, the program started recognizing the mesh, when I enabled 'Save all (ignore physical groups)' option, while exporting the SU2 mesh from Gmsh.
Thank you for the quick response. Could you also explain what this option does ?
NACA0012 with simpleFOAM nuovodna OpenFOAM Running, Solving & CFD 7 May 19, 2010 04:58
Cross-compiling OpenFOAM 1.6 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 7 January 19, 2010 15:39
OpenFOAM Message Board Email notification stopped working mbeaudoin OpenFOAM Bugs 3 January 8, 2009 22:08
Windows Installation BugsComments on Petrbs patch brooksmoses OpenFOAM Installation 48 April 16, 2006 00:20
Windows Installation Petrbs Port Redux Patches and Binary Distribution brooksmoses OpenFOAM Installation 0 February 10, 2006 17:35
