October 14, 2016, 17:55 |
Strange Error Related to Pointers
Peter
Rep Power: 9 |
I'm getting this error using a custom mesh. My config file is essentially the same as the base version with the boundary names and input file being all that is changed. What does this error mean, and how can I fix it? I can attach any files if needed. Thanks!
SU2_CFD(956,0x7ffff43d23c0) malloc: *** error for object 0x7ff3ec4768e8: incorrect checksum for freed object - object was probably modified after being freed. *** set a breakpoint in malloc_error_break to debug Abort trap: 6 |
October 17, 2016, 03:33 |
Rep Power: 12 |
Did you try to run first SU2_MSH to check if the error is in the mesh?
[blockMesh] Strange non-hexahedral cells? | maka15 | OpenFOAM Meshing & Mesh Conversion | 3 | May 19, 2016 08:56 |
[surface handling] surfaceFeatureExtract strange behavior | wc34071209 | OpenFOAM Meshing & Mesh Conversion | 0 | March 11, 2014 09:22 |
strange pressure behaviour with symmetricPlane boudary condition - interFoam | duongquaphim | OpenFOAM Running, Solving & CFD | 10 | August 20, 2013 14:00 |
Strange residuals behaviour | xxxx | Main CFD Forum | 1 | July 13, 2013 14:40 |
A Strange Problem in making Parallel (Ansys/CFX 12) | a.sarami | CFX | 13 | October 7, 2010 01:33 |
