Home > Forums > Software User Forums > SU2
[SU2] Axissymmetric nozzle flow, initialization, force calculation etc.
Old   April 10, 2019, 09:40
Red face [SU2] Axissymmetric nozzle flow, initialization, force calculation etc.
atelcikti1's Avatar
atelcikti1 is on a distinguished road
Hi Community,
I'm dealing with with internal flow analysis of solid propellant rocket motor nozzle. I have walls, pressure inlet and outlet (which is large domain like far-field).
I have few problems about initialization and force calculation.
First of all, For convergence I have to initialize my case with chamber total conditions which is similar to pressure inlet conditions. Therefore, I set my reference quantities such as reference_temp, reference_press as inlet quantities. Then I successfully obtain the results in contour plot which I expect indeed.
However, I need also thrust value which is obtained by wall forces (just forget about inlet). When SU2 write the CL and CD values on terminal, they are all meaningless. Because SU2 uses the reference quantities (which is my inlet total conditions) to calculate Force. I have checked the source code (CEulerSolver::Pressure_Forces). I am sure about the force calculation is CL or CD = (P-Pref)/(0.5*Rho_ref*Vref^2*Sref).
In order to solve this problem. First I solve the case with reference quantities as inlet conditions and converged it. Then I used restart file and changing the reference quantities which satisfy (0.5*Rho_ref*Vref^2*Sref) = 1 , run again. Force results are still meaningless. By the way, I need also some explanation for axissymmetric force factor etc. which can also be a problem.
I hope, I can explain the situation. Any help will be appreciated.
Best regards.
atelcikti1 is offline   Reply With Quote
Old   April 11, 2019, 02:04
Smile
atelcikti1's Avatar
If it is not well understood, I can further explain the used domain with some visuals.
Old   May 4, 2019, 15:19
pcg
Pedro Gomes
pcg is on a distinguished road
Hi Ali,
You can use the values in the "forces_breakdown.dat" file, there are force coefficients (the denominator for the normalization is also in the file) listed by surface in there, so it should be straightforward to convert those to force along some direction.
Cheers,
Pedro
pcg is offline   Reply With Quote
force, initialization, nozzle, reference quantities, su2
Flow Coefficient calculation in Star-CCM+ sazrul STAR-CCM+ 1 October 18, 2016 10:44
Stability Problem with sonicFoam for Nozzle Flow Julian K. OpenFOAM 3 July 11, 2016 08:14
Having Problem solving 2D supersonic flow around a plug nozzle chrislloyd FLUENT 7 July 22, 2015 13:09
reversed flow in over-expanded supersonic nozzle imnull FLUENT 0 March 28, 2013 10:48
UDF for transient pressure inlet, mass flow check at nozzle exit and volumetric heat kokoory FLUENT 0 August 17, 2011 02:07
