Home > Forums > Software User Forums > SU2
Multi Fluid Flows - Mixing
Old   February 10, 2017, 13:29
Default Multi Fluid Flows - Mixing
Mark Beeman
fishbone is on a distinguished road
I was wondering if SU2 currently has the capability to solve multi fluid flows for mixing problems e.g. water and oil or air and halon. I don't want to have to rewrite the solver, but if it is a matter of adding some fluid properties to a data base, that would do.
I know that OpenFoam does this (the oil/water example was illustrated in an OpenFoam example), but I think 95% of the other problems we do in my work is more suited to SU2. I don't use either OpenFoam or SU2 at the moment (we use 3 other codes, but only one does multi-constituent flows) but if one of these supports the capability to do this, we would love to give it a shot.
Any input is appreciated.
MArk
fishbone is offline   Reply With Quote
Thread Tools
Trackbacks are On
Wrong multiphase flow at rotating interface Sanyo CFX 14 February 7, 2017 18:19
Mixing Problem in Double Pipe Heat Exchanger With Fluid Fluid Interface Shomaz ul Haq CFX 3 December 17, 2015 13:50
Incompressible, miscible mixing of two fluid stream OpenFOAM Nishchal OpenFOAM Running, Solving & CFD 4 July 31, 2013 09:54
Density of multi fluid simulation unischlaf CFX 4 September 18, 2011 04:16
Simulate mixing of two different flows in FLUENT Masood FLUENT 1 June 25, 2007 11:46
